Old 01-16-2010, 08:02 PM   #1 (permalink)
ecomonkey
silver clown - '02 echo 2 door base
90 day: 45.48 mpg (US)
echo bellypan install with pics and template
here is my front bellypan for my 2002 echo. it took around 4 hours kind of leisurely working. i used a hacksaw blade a razor knife and regular handtools. it is 4 mm coroplast from a plastic supplyer "Farco plastics" in jax florida. it is thru bolted in around 8 spots,. i think you can read the measurements from the photos i hope. any body with an echo or xb can probably use the measurements.total cost $14.00 middle and rear coming soon.
The Following User Says Thank You to moonmonkey For This Useful Post:
alohaspirit (01-17-2010)
Old 01-16-2010, 10:13 PM   #2 (permalink)
Tank - '76 El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 190 E
90 day: 37.07 mpg (US)
Angel - '88 420SEL
Last 3: 23.01 mpg (US)
Niice can't wait for results
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 01-16-2010, 10:29 PM   #3 (permalink)
Lead-footed Econewbie
Ceffy - '97 Cefiro 25 excimo
90 day: 23.27 mpg (US)
Very nice. How are the panels attached? I see you mention bolting, have you drilled new holes or have you used existing holes?
Old 01-16-2010, 10:37 PM   #4 (permalink)
ecomonkey
There are holes in the original front pan i used 4 of them and drilled 2 holes thru the bumper near the front,, its a pain to get to the bolts to put the nuts on them, but it can be done,, my nephew has way skinner arms and could get his hands all the way down to the bolts to put nuts on them by reaching down behind the headlights., i double nuted them so they wont vibrate out the bolts are 1/4 by 2 inchs long, i used large fender washers so the coroplast wont tear,
Old 01-17-2010, 12:51 AM   #5 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.5 mpg (US)
those pics are tiny but i think i can see the measurements
did a nice job man
cant wait for the results
Past Present Future?
Old 01-17-2010, 04:12 AM   #6 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
moonmonkey -
That's a cool belly pan. Most egg-salad execution.
CarloSW2
American Solar Energy Society
Old 01-17-2010, 05:28 AM   #7 (permalink)
Hypermiling rookie
Laurentiu's Avatar
Opel Corsa B - '96 Corsa 1.2 8V
90 day: 47.27 mpg (US)
VW Bora 1.6 16V - '02 Bora/Jetta
90 day: 34.01 mpg (US)
nice...I wish this coroplast stuff was readily available where I live
"It has been my observation that most people get ahead during the time that others waste" Henry Ford
Old 01-18-2010, 04:46 PM   #8 (permalink)
Cougar - '00 Cougar SE
Blue - '04 Echo RS
90 day: 36.44 mpg (US)
Nice work, i was thinking of doing a simple rear diffuser for the rear since that will close up the rear suspension area and help with the drag underneath/exiting the car.
Old 01-18-2010, 11:49 PM   #9 (permalink)
ecomonkey
what would your diffuser look like? be made of ? be mounted?
Old 01-19-2010, 08:33 AM   #10 (permalink)
vtec-e's Avatar
De Yaris - '04 yaris T2
90 day: 69.55 mpg (US)
I tried a rear belly pan and it sealed nicely. But the angle was way more than the 4 deg required so i didn't get any real benefits from it. I had a curved sheet of aluminium covering the rear axle to seal it off but the axle hit it a few times when the suspension extended after some speed bumps etc. I haven't put it back on yet due to it being freezing cold here. Thing is, if i lower its angle to 4 deg it will be a lot lower than the lower edge of my rear bumper. Getting it to look the part will need some thought.
I'll post pics i promise.
ollie
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/echo-bellypan-install-pics-template-11893.html
Posted By For Type Date
Belly Pan replacement options? This thread Refback 12-30-2011 09:35 AM
EcoModder.com Latest Blog Posts This thread Refback 01-23-2010 02:29 AM
