Good to know that you have decided to put some wheel covers on your echo!
It was pretty simple. We drilled 3 holes in the original hub cap, and in the pizza pan. Then we nailed it together with nut and screw. Did the same for the 4 wheels.
I don't know if you can see in the photo, but the nails are placed at the extremity of the cover. FYI : If you plan to put some Wheel skirts, make sure that the pizza pan do not take to much place, every inch is very important for good AF.
