Old 05-18-2010, 03:16 PM   #1 (permalink)
Electronic vs vacuum/mechanical timing advance
Hello.
I have a 1991 Metro with a vacuum advance distributor. I also have a junker 1992 Metro with an electronic advance distributor. Based on the assumption the elctronic control is better than the vacuum control, I would like to use the 1992 distributor. After looking at the wiring diagrams, it appears that I would have to swap out the ECU if I were to use the electronic distributor in the 1991 Metro.
Is this correct?
Are there any issues with swapping a 1992 ECU with a 1991 car? Will I have to swap any other components in order to make the ECU happy? Will I have to move wires around on the multiwire connectors?
Thanks.
- Peter
Old 05-19-2010, 04:51 AM   #2 (permalink)
Custom User Title
Nut Wagon - '91 Civic Wagon DX
90 day: 52.46 mpg (US)
You'll have to make a bunch of changes to the wiring. The '92 ECU won't plug into the '91 wiring harness.
Driving a 1991 Honda Civic Wagon and building a 1994 Geo Metro XFi.
Best tank with the Honda so far is 61.65 MPG.
Old 07-02-2010, 12:18 AM   #3 (permalink)
Will it be that hard to do? I was thinking of swapping the distributor too but if it is too painstaking then I might change my mind instead.
Old 07-09-2010, 12:23 PM   #4 (permalink)
My experience with the Metro is very limited, but I've lots with some other cars that also went from Mech -> Elec on the distributor. And, the ones I know about, the swap would be very very hard to do. 99% of them do indeed require you to swap the ECU over, and most of these swaps involved a lot more than just plug-n-play. I can't think of one where all of the ECU Pins even matched. Granted, the Metro might not be as complex as others, but I think you'll be doing way more work than it's really worth. The gains will most likely not justify the work.
Not the answer your looking for I'm sure, sorry I couldn't offer more help.
Sorry, new users are not permitted to post links in their signatures.
How to advance timing? wyatt EcoModding Central 14 03-16-2010 04:14 AM
Experimenting with tuning leaner and ignition timing. Trike EcoModding Central 3 10-16-2009 12:22 PM
Advance or Retard Timing for better mpg? C3Killer EcoModding Central 8 07-22-2008 07:05 PM
Timing advance or retard? klrv6 General Efficiency Discussion 4 06-09-2008 09:51 PM
Metro Timing Advance?? SirKeats EcoModding Central 10 05-29-2008 01:24 AM
