Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 12-16-2011, 11:33 AM   #1 (permalink)
60+ mpg at posted speeds
California98Civic's Avatar
Black and Green - '98 Civic DX Coupe
90 day: 64.83 mpg (US)
ELVIS is knocking
What is this? elvis recipe
"Electrochemical Liquid Vortexing Ionization System"?
Black and Green will be rebuilt over decades as parts die--until it becomes a different car. Goal is only 60-70 mpg at posted speeds. I'm not trying for highest possible mileage.
Calculators: standard deviation, Ohms Law, & drag HP losses.
Old 12-16-2011, 01:12 PM   #2 (permalink)
Eco-ventor
Princess - '92 MX-3 GS
House of Tudor
90 day: 33.52 mpg (US)
Send a message via MSN to jakobnev
Remember, even if you win the rat race - you're still a rat.
2010: 454.92L for 5313.90km => 8.56L/100km (27.5MPG US) (5 months)
2011: 606.11L for 7754.04km => 7.82L/100km (30.1MPG US) (Full year)
2012: 170.10L for 2405.00km => 7.07L/100km (33.3MPG US) (In progress)
The Following User Says Thank You to jakobnev For This Useful Post:
California98Civic (12-16-2011)
Old 12-16-2011, 08:40 PM   #3 (permalink)
Originally Posted by jakobnev View Post
hahahahahahaha!!!!
Old 12-16-2011, 09:39 PM   #4 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
No,no, they have real science. Look at the pretty drawing DIY Fuel Ionizer for real cheap. Really works.
Isn't this what NASA uses ?
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 12-17-2011, 12:07 PM   #5 (permalink)
In the comments, here's a response that looks like it could have come from members of ecomodder.com:
makenakai -
I looked at your test results.
There's only one baseline measurement, so it's really not possible to statistically know the true baseline values, but the ELVIS tests have an average CO% of 0.86 and a standard deviation of 0.25%. This excludes the two measurements with 0.00 CO%, as those should almost certainly be taken as outliers. The baseline CO value is 1.7 standard deviations from the average ELVIS CO measurement.
Given the variation in your data, if you test 50 times you would expect 5 results that are at least 1.7 standard deviations from the mean. Typical statistical significance of a difference between the two conditions - with and without ELVIS - would be assigned if the distance is 1.96 standard deviations or more.
Regarding the hydrocarbons, your baseline is only 0.32 standard deviations from the mean of the ELVIS tests. By all measures, the two conditions can be statistically assumed to be identical.
Do you have more baseline data? That would help firm up the interpretation - it could even help your case.
Old 01-14-2012, 07:40 PM   #6 (permalink)
skyking's Avatar
Woody - '96 Ram 2500 SLT
90 day: 20.74 mpg (US)
Avion and Woody - '96 Ram 2500/5th wheel combo
90 day: 15.87 mpg (US)
from Jason's link:
the outbound fuel stream is spun into a high speed vortex that braids the liquid inwardly into a higher energy imploded state.
Head asplodes!
1996 Dodge 2500 Cummins Turbodiesel
Custom cab, auto, 3.55 gears
