Old 05-07-2009, 11:49 AM   #1 (permalink)
In persuit of Efficiency
zman's Avatar
Bouble - '01 Echo 2 door
90 day: 41.62 mpg (US)
Engine idle speed
The goal of my mods is to eventually unload my Toyota Echo 1.5 L motor from the alternator (do the regen braking thing) the A/C (which I hardly ever use), and possibly make the water pump electric driven.
My question is the idle speed of the motor, will it change? And if so will it lower or increase? And am I going to see FE improvement when in idle?
Old 05-07-2009, 01:48 PM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 59.38 mpg (US)
The idle speed will remain the same. The ECU keeps a certain idle speed and adjusts the amount of fuel to stay there. You can observe this by suddenly turning on a large load when in idle (defroster, lights, etc.). The sudden load slows the engine down, but the ECU adds fuel and the rpms go back to normal.
If you take off your alternator or AC belt, then the load on the engine will be smaller, so less fuel will go into keeping it at idle speed.
Piwoslaw's Peugeot 307sw modding thread
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 01:59 PM
Idle Speed Adjustment '89 Metro SirKeats DIY / How-to 7 02-08-2010 03:23 PM
Low-speed "cruise control" using idle speed controller? Bearleener Hypermiling / EcoDriver's Ed 0 01-14-2009 11:21 AM
Altered Idle Speed After Performing EOC Tango Charlie Hypermiling / EcoDriver's Ed 20 11-19-2008 01:41 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
