Old 08-29-2014, 06:14 PM   #1 (permalink)
EngineLink APP OBD2 Reader for iPhone
Engine Link - OBD II vehicle monitoring and diagnosis
The reason to start this thread is to: introduce the app, discuss using this app for fuel efficiency purpuse. Here is an screenshot for the app.
Old 09-03-2014, 06:47 PM   #2 (permalink)
EngineLink App BENEFITS
* Emission Test.
* See what your car is doing in real-time.
* Read and clear OBD fault codes.
* Display car performance and sensor data.
* Customizable gauges, showing only the data you were interested in
* Top Ranked Car App
Old 09-03-2014, 07:16 PM   #3 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
How does it connect to the car?
Old 09-03-2014, 07:29 PM   #4 (permalink)
OBDII port
All cars and light trucks built and sold in the United States after January 1, 1996 were required to be OBD II equipped.
You can plug a Bluetooth Low Energy adapter or a WIFI adapter to that OBDII port under your vehicle dashboard. The app will talk to it via Bluetooth or WIFI.
Old 09-03-2014, 07:49 PM   #5 (permalink)
dirtydave's Avatar
Duct Tape Aero Crew
Team Chevy
So this works with the cheap elm bluetooth adaptors? I have an old iphone 4s i will check it out and let you know! I have a new battery in the mail now.
Old 09-03-2014, 08:18 PM   #6 (permalink)
Bluetooth adapter
Do you have a link for your Bluetooth adapter? There are 2 kinds of Bluetooth adapters.
1. For Bluetooth Low Energy Adapter (aka Bluetooth 4.0), it will work right away. Auto configure, auto connect.
2. For Generic Bluetooth ELM327 (Bluetooth 3.1) device: iPhone/iPad has restriction on Bluetooth support (Basically iPhone/iPad/iPod requires BT data device to have a special Apple authentication chip which 99% of the BT adaptors don't have). In order to use standard Bluetooth devices in data mode you need to jailbreak your iPhone. There is a tool in Jailbreak store to manage the Bluetooth. If you have jailbreak iPhone/iPad and that tool installed, you should be able to use Engine Link with the OBD II Bluetooth device.
Old 09-03-2014, 11:10 PM   #7 (permalink)
dirtydave's Avatar
Duct Tape Aero Crew
Team Chevy
New Auto ELM327 V1 5 Interface Bluetooth OBD 2 OBDII Car Diagnostic Auto Scanner | eBay
This is the device I have it has worked great with all 5 of my android devices. I do have a jail broken iphone 4s with a dead battery. I got it from a friend I ordered a new battery and after I get it up and running I will try to get it to work. Can you link the other OBD2 device that will work with a stock iphone?
Old 09-04-2014, 12:31 PM   #8 (permalink)
Bluetooth Low Energy Link
You can find the Bluetooth Low Energy adapter at ebay by search LELink.
Old 09-04-2014, 12:32 PM   #9 (permalink)
You can find Bluetooth Low Energy adapter at the outdoor-apps site at Outdoor Apps In The Palm Of Your Hand
Old 09-04-2014, 02:15 PM   #10 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
At $45 + $5s/h you should just spend the extra $20 and buy an ultra gauge. Torque app is popular because the blue tooth thingys are like $5...
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
