Old 12-24-2012, 02:40 PM   #1 (permalink)
Evaporative air cooler for A/C?
How would evaporative air conditioning work in cars?
Evaporative cooler - Wikipedia, the free encyclopedia
IMO refilling the tank with water would be a minimal hassle, but
* It might not cool enough, specially in hot yet humid climates.
* Air might get too humid, thus air exchange might be needed. It can even be combined with some short cycles of regular A/C to reduce humidity.
* Mildew and fungus might appear on the car upholstery.
* Maybe sloshing due to car movement might be an issue.
Ideas?
Old 12-24-2012, 02:50 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...my parents had one on our '55 Ford station wagon, worked great when humidity was low...and the water hadn't evaporated away!
...you can sometimes see one on a car at "oldie" car shows:
...of course, it's NOT very aerodynamic! But, maybe the same idea could be "incorporated" INSIDE the body sheet metal with a NASA inlet air scoop?
...earlier post on this subject: http://ecomodder.com/forum/119943-post16.html
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
Old 12-24-2012, 02:55 PM   #3 (permalink)
nemo's Avatar
Chief - '06 Grand Prix Base
90 day: 29.08 mpg (US)
SF1 - '012 Fiesta S
90 day: 28.55 mpg (US)
Just looking at that I would think that the increased drag would make standard AC more efficient.
The Following User Says Thank You to nemo For This Useful Post:
Cobb (12-25-2012)
Old 12-24-2012, 03:41 PM   #4 (permalink)
As Old Tele man showed they are popular with air-cooled VW people. But then so are roof racks filled with ice boxes and vintage luggage.
I had one once, and the problem I had was that if I opened the other window to let air flow back out, that overpowered the cooling effect. If I sealed up there was no air flow through the unit.
Old 12-24-2012, 03:48 PM   #5 (permalink)
...beats walking...
...we (on '55 Ford wagon) cracked a rear window on the opposite side for 'cross' flow.
Old 12-24-2012, 05:42 PM   #6 (permalink)
V8 guy
Sub - '84 Diesel Suburban C10
Pickups
90 day: 18.91 mpg (US)
camaro - '85 Camaro Z28
Towncab - '00 Town car
90 day: 18.87 mpg (US)
It wont work in miami. They barely work here in the high plains of NewMexico where humity can normally be between 17% and 25%.
1985 chevy camaro mostly stock.
Old 12-24-2012, 06:26 PM   #7 (permalink)
That could work. In 1957 the pop-open rear windows on the Beetle were an option (I didn't have). The driver door vent wasn't effective and just cracking the driver side window overpowered the restricted flow through the 'swamp'.
Old 12-26-2012, 12:29 AM   #8 (permalink)
Swamp-coolers are a popular option among truckers in Brazil, since it doesn't require to get the engine on just to get the A/C on while sleeping.
Look at the top-mounted box: that's the main unit. Some are self-contained, but others have auxiliary water reservoirs to be mounted at random spots in the truck.
Old 12-26-2012, 12:31 PM   #9 (permalink)
...beats walking...
...here's an MIT Master's Thesis paper on an automotive evapcooler conditioning system:
http://dspace.mit.edu/bitstream/hand...369202.pdf?...
Old 12-27-2012, 06:05 PM   #10 (permalink)
It's not so hard to get evaporative coolers in Brazil. My grandma has one in her house.
Joape - Indϊstria de Equipamentos Ambientais Ltda. - that's a company which makes evaporative coolers in my hometown
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
