Old 08-23-2010, 01:13 PM   #11 (permalink)
QuickLTD's Avatar
Flying Brick - '96 Bonneville SE
90 day: 23.57 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
An easily overlooked part of the Daytona/Superbird aero pkg. The rear window has been pushed out to the body lines.
1996 Pontiac Bonneville SE 3.8L V6
Old 08-23-2010, 01:20 PM   #12 (permalink)
The SHOW - '95 SHO Taurus
I forgot about the window! And I have a friend with one of those cars, how stupid of me. Yeah, it was a little more than simple bolt on items on that one.
Brian
Old 08-23-2010, 01:25 PM   #13 (permalink)
That Pontiac is even better than the Monte Carlo!
Brian
Old 08-23-2010, 04:51 PM   #14 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
not as glamorous as the cars above but nevertheless a very serious factory aeromod was that of the opel kadett e, standard vs GSI
where the standard car had a 0.32Cd wich was quite spectacular for a small hatch in the 80's
but the gsi lowered this to 0.30 with the addition of small hood vents a rear spoiler a different bumpers and moldings in front of the rear tires
it's remarkable that such subtle changes brought about such a great improvement
aerˇoˇdyˇnamˇics: the science of passing gass
*i can coast for miles and miles and miles*
Old 08-23-2010, 05:18 PM   #15 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Hello -
In a post I can't find, aerohead said that the original S-Series coupe would be a good platform for aero-stuff. It's also light, so it would be good for electrics. It was even a mule for the GM EV-1. Here is a side view :
You can see the very-close-to-covered wheels, clean flowing lines, and the swoopy nose.
Here is the front view :
The small front radiator opening is typical of a lot of late 1980's aero-designs. What I hadn't noticed before is what appear to be front wheel deflectors on each side. I am positive that between those deflectors would be a black plastic deflector to deflect air onto the radiator.
CarloSW2
American Solar Energy Society
Old 08-23-2010, 08:49 PM   #16 (permalink)
3dplane's Avatar
Chick magnet... - '-1806 Protege DX
90 day: 57.78 mpg (US)
Wife's Fiesta - '011 Fiesta SE
90 day: 36.51 mpg (US)
@cfg83! I got one of these sitting in the yard. Well, mine has the spoiler on the deck lid ( I guess that's the SC2 )
What appears to be a radiator opening ( Behind front plate in your picture )
is actually blocked off,fake opening.
You are right between the two deflectors there is a scoop type air intake.
( on mine it's broke off but at the edges I can see what it used to look like when it was there )
Unfortunately no title for it so I can't drive this little aero car : (
Barna
Old 08-23-2010, 09:21 PM   #17 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
3dplane -
That's neat! The fake opening makes it more aero than I thought. Too bad about the title.
CarloSW2
Old 08-23-2010, 09:36 PM   #18 (permalink)
3dplane's Avatar
Also interesting to note the little cup shaped ridges directly below the headlamps. They are probably some kind of turbulators for the time when the lights are opened up so the open lamps are not cutting into clean airflow,rather
ride behind a bubble of higher pressure air? I'm just guessing.
Of course it's a compromise because when the lamps are closed,the airflow could be cleaner without them.
I'm yet to see another car made with only a bottom air scoop and no other openings on front. It sure looks like they paid attention when designing the SC.
Old 08-24-2010, 04:22 PM   #19 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
The other major change was the grill - swapped for the cheap one-piece big opening version for the small slit on the GSi / GTE. That version of the Astra / Kadett was good though - a kind of magic sweet spot of early 80s lightness, and mid-80s aero before weight became a serious issue for most cars.
No longer here. Bye, and good luck to all.
Old 11-06-2010, 04:30 PM   #20 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
My S series would get 40 MPG on the highway.
Funny, 1970s they knew about droopy noses with small grills and sloping rears.
What happened in 40 years?
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
working on my aero mods pgfpro Aerodynamics 14 09-23-2009 10:26 AM
Aero mods using RBL collision wrap pgfpro EcoModding Central 28 08-31-2009 02:40 AM
Interesting story that's hard to find RandomFact314 EcoModding Central 1 06-09-2009 01:08 PM
Scion xB Aero Mods, Billy Gibbons trikkonceptz EcoModding Central 1 05-09-2009 03:27 AM
New Swift aero mods ptr Aerodynamics 25 04-11-2009 05:24 PM
