Old 09-29-2011, 11:35 AM   #1 (permalink)
Eco-ventor
Princess - '92 MX-3 GS
House of Tudor
90 day: 33.52 mpg (US)
Send a message via MSN to jakobnev
Failed emissions -92 MX-3 GS
A week ago poor Princess failed emission with the following results(limit in parenthesis):
  • CO 2.1(0.5)%
  • CO2500 0.6(0.3)%
  • HC 235(100)ppm
  • Lambda 0.98(0.97-1.03) (Passed, but listed for reference)
A while back the ignition module failed on me, and while diagnosing there was a lot of starting. So i suspect that the oil is flooded gas soaked, i'll be changing that soon, and also checking ignition timing, since it may have shifted when i disassembled the distributor.
There is another symptom also: When hot she hesitates on low revs, but runs fine otherwise. I hope it's nothing more expensive like lambda probes or MAF sensor.
I'd also like to know if anyone has had problems from EOC:ing too much, like 70% of their distance.
Remember, even if you win the rat race - you're still a rat.
2010: 454.92L for 5313.90km => 8.56L/100km (27.5MPG US) (5 months)
2011: 606.11L for 7754.04km => 7.82L/100km (30.1MPG US) (Full year)
2012: 170.10L for 2405.00km => 7.07L/100km (33.3MPG US) (In progress)
Old 09-29-2011, 02:29 PM   #2 (permalink)
Phantom's Avatar
Bonnie - '98 Bonneville SSE
3800
90 day: 26.91 mpg (US)
How old is your MAF sensor? It might need to be replaced also did you have the spark plugs replaced? Try cleaning the MAF remove the MAF and Clean it with electronics cleaning spray let completely dry before installing.
I move at the speed of awesome.
The Following User Says Thank You to Phantom For This Useful Post:
jakobnev (09-29-2011)
Old 09-29-2011, 03:56 PM   #3 (permalink)
Eco-ventor
House of Tudor
The spark plugs are new, the MAF sensor otoh i think is as old as the car. I'll look at it tomorrow, thanks for the tip!
