Old 11-11-2009, 11:18 PM   #1 (permalink)
Silver Bullet - '00 Firefly 4 door model
90 day: 12.74 mpg (US)
Fixed my oil drip
Ive had a bad oil drip from the oil pan, coming from the crankshaft position sensor wire. Some said it was the rear main oil seal. There was this fluid additive at only one parts store in town. I only added half the bottle to the oil change, and it actually worked.
BAR’S LEAKS REAR MAIN SEAL REPAIR
Bar's Leaks Rear Main Seal
2000 Firefly 4 dr Automatic
Old 11-11-2009, 11:29 PM   #2 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.26 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
never used that but they make radiator tabs that are fantastic!
They last and dont plug what they aint supposed to.
BTW, your gas mileage seems mighty low for a firefly.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 11-11-2009, 11:32 PM   #3 (permalink)
it's just that I entered all my data in kilometres not miles. Their needs to have the option for both miles and kilometers on the fuel log.
Old 06-07-2011, 08:35 PM   #4 (permalink)
upadate: the problem was not the rear main seal. it was the oil pan seal. i applied a new seal with the paste and now it is problem free.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 05:04 AM
Article: Crude oil is getting cheaper — so why isn't gas? Frank Lee The Lounge 20 07-14-2010 02:06 AM
Restore oil additive... suspectnumber961 Success Stories 43 05-14-2010 04:40 PM
crankshaft position sensor oil drip TheSilverBullet Off-Topic Tech 5 11-12-2009 01:21 AM
