Old 10-19-2008, 10:06 PM   #1 (permalink)
Hydrogen Nut
Ptero's Avatar
Smart Car ForTwo Pure - '08 Fortwo Pure stripped
90 day: 51.35 mpg (US)
BMW 750iL V12 - '90 V12
Wildfire 250C - '08 250C
Free: spring-loaded air dam in San Bernardino, CA
This was the first air dam I built for my new Smart Fortwo Pure. I cut it from some PVC sheet I had laying around and mounted it on a spring-loaded hinge so it would flip up against the bottom sheeting if I hit something like a thrown truck cap, but easily snap back into place with a simple pull.
It was kind of an experiment to find out how effective it would be on the Smart. It scraped a lot because I mounted it way loooooow for maximum aerodynamic effect. There was a question about whether or not the drag induced by the dam was greater than the drag it eliminated because the Smart has a pretty clean underbody. I use a 7-mile downgrade and an anemometer to try to verify aero mods. It seemed to go a lot faster so I was getting pretty stoked about it when I left for Phoenix.
I was convinced at the time that I was getting better mileage but I didn't really get enough time to test it. What was absolutely certain was that it was much more stable in crosswinds. Dramatically more stable.
But then disaster struck. I was drafting a truck in heavy traffic (for survival, not mileage) on the San Bernardino freeway before the overpass into Riverside when I hit a thrown truck cap. Unfortunately, this cap was folded over on top of itself and was sticking up pretty high, pretty high like 5 or 6 inches when I rammed it. There was a really loud bang. I pulled into a rest stop near Needles to pull the air dam back out but it was gone.
It's yours if you can find it.
The next dam will be more forgiving. Maybe bristles or something. I've been looking at plastic broom heads with poly bristles that I could cover with cheap, sacrificable pvc sheet or tape. Still thinking about it.
With bristles, I could let some air out of my tires and sweep parking lots for gas money.
Ptero
Kicked off CleanMPG in 2012 for my comments about the Chevy Volt http://forum.ecomodder.com/images/smilies/eek.gif
Old 10-19-2008, 10:23 PM   #2 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.61 mpg (US)
Silver Bullet - '00 Insight
90 day: 60.3 mpg (US)
Hey, welcome to ecomodder, Ptero!
If the airdam produced that much of a noticable difference, I would encourage you to try again!
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 10-20-2008, 12:23 PM   #3 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Welcome to Eco-Modder
Sounds like a great Idea; Do it again!
6 speed ALH TDI
Old 10-20-2008, 01:24 PM   #4 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
What did you use for the spring mechanism?
Old 10-20-2008, 09:00 PM   #5 (permalink)
Hydrogen Nut
Ptero's Avatar
I wanted it to break away rather than cause damage to the Smart, so it was pretty light and only held in place by two belly panel screws. Two six inch 3/8-inch dia springs were attached to openings near the lights to short rods protruding from the top of the air dam to hold it in place under tension. If it encountered an object, it would pivot on short brackets, rotating slightly down and rearwards, and it would fold upwards in the center. The springs would wrap downwards and loose their pull and the dam would remain horizontal until you pulled it back, then it would snap into place. It survived several previous thrown caps before it broke free, and when it did, it just sheared the heads off the mounting screws and straightened out the spring hooks, taking them with it. Like it was never there. I really liked it. But the scraping was pretty irritating. The wheelbase of the Smart is so short that when you hit the brakes, the dam would scrape. The amazing thing was that after a LOT of scraping there was absolutely no loss of plastic at the base of the dam. It was just noise. It made pedestrians drop things.
I've decided you can't do an air dam on a Smart without adjustable air shocks. Oh, and I'm going to drop it a couple inches by modding the springs when I get them.
Ptero
Old 10-20-2008, 11:21 PM   #6 (permalink)
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
I love the idea of a break-away air dam. Seems like the biggest problem with these is hitting curbs and speedbumps. Something that flips up solves that!
Hmmm. - broom bristles....
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 10-21-2008, 09:19 AM   #7 (permalink)
Deadly Efficient
Originally Posted by Ptero View Post
...But the scraping was pretty irritating... It made pedestrians drop things.
That's funny right there! I'm just ornery enough that making pedestrians drop things would be reason enough to install an airdam!
-Terry
My Pet Threads:
aerodynamics, air, dam, smart
Effects Of Air Dam (Ford F350 pickup) Big Dave Aerodynamics 59 05-06-2012 01:32 PM
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 09:30 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
