Old 07-26-2008, 08:10 PM   #1 (permalink)
Polymer - '89 Civic Hatch Std 4 speed
Woodstock - '69 Midget 1275
Nekobus - '06 xB
Cool Fuel Cut/Engine Shutoff Switch (Success!)
'89 Civic 1.5L M/T
Success!
I tapped a on/off switch into fuse 14 (cuts off the whole main relay as well as several vacuum/emissions valves all over the engine.)
I took it out for a test drive and it works GREAT. No crazy error code from the ECU, just the check engine light stays on until I bump-restart. A very pleasant affair, really.
I want to run one more wire to ground the switch (so the switch LED comes on!), and I also have to verify that I have tapped into the wire AFTER the fuse. If my circuit fails, I want it to be properly fused so it doesn't start a fire. Then it'll be done.
On with the ing!!
Old 07-26-2008, 08:25 PM   #2 (permalink)
Nekobus - '06 xB
Originally Posted by reformed View Post
Much better off cutting the spark instead of the gas IMO. The blue wire at the distributer, should do the trick on your car.
I wasn't confident with tapping into the distributer. 30,000 volts scares me. :P
Plus, I'm not sure I want to be pumping unburnt fuel into my VERY leaky exhaust system. I bet more exhaust comes out at the downpipe than at the tailpipe. It sounds like a harley.
Old 07-28-2008, 11:14 AM   #3 (permalink)
Nekobus - '06 xB
Another added bonus that I discovered this morning!!!
Flipping the kill switch doesn't disable my turn signals like switching the ignition off used to!!
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 03:29 PM
Fuel Economy related papers tasdrouille General Efficiency Discussion 31 01-18-2011 11:48 AM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 23 04-10-2010 01:22 PM
Fuel Cut/Engine Shutoff Switch (Failed Attempt) millenniumtree EcoModding Central 6 07-26-2008 08:22 PM
DIY decel fuel cutoff; alternator regulation; auto start/stop MetroMPG EcoModding Central 0 11-29-2007 03:04 PM
