Old 05-07-2008, 09:15 PM   #11 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Grand Voyager SE
my issue is not turning off the car but turning it back on. Is there a way to do this without the starter? In my old E150 van stick with dual tanks when I was not paying attention and ran out of fuel the engine would die I would simply flip the tank switch and within 30 seconds the engine would just start right up again and off I go.
Is there anyway to do THIS? IE my idea is a kill switch momentary. I press the button the car shuts down I release the button it starts up again without the starter (like the van did) if thats possible. Suggestions?
I am also thinking a FOOT switch to engage the starter. so with my left foot I can depress the switch to restart the engine (for when I slow down too far to restart normally or if I EOC to a stop etc..)
Suggestions?
Old 05-07-2008, 09:50 PM   #12 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
[QUOTE=JohnnyGrey;23986]So then your ECU is trying to ground 12v? That can't be good.
Yes, that is exactly how most systems work. Keep in mine there is a big resistor in series called a fuel injector.
Just put your momentary kill switch right in the power wire to the injectors.
Second pic switch mounted on shifter knob.
Old 05-08-2008, 03:05 PM   #13 (permalink)
Bucket - '94 Escort Wagon
90 day: 36.46 mpg (US)
Thanks John, I'm going to try to find electrical schematics for my PT Cruiser so I can do just that.
Old 05-08-2008, 03:25 PM   #14 (permalink)
Pushrod - '02 Cavalier
I knew that much. By the way you wrote it, I thought your kill switch supplied + to the switched side of the injectors, rather than cutting off the + to the common side.
Fuel Economy related papers tasdrouille General Efficiency Discussion 33 03-06-2012 12:22 PM
Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15% SVOboy Aerodynamics 11 12-27-2011 07:18 AM
Coasting in gear vs. neutral (fuel cut feature) WTFM8 Hypermiling / EcoDriver's Ed 28 05-29-2011 10:39 AM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
Petroleum inflation could pump up price of plastic Frank Lee The Lounge 3 04-11-2008 04:40 AM
