Old 09-08-2010, 06:56 PM   #1 (permalink)
Lone Ranger - '97 Ranger Splash
90 day: 28 mpg (US)
Which gears in my rear end?
As I have said before I am not a "car guy". Just a guy trying to get the most out of what I have and improve when I can afford.
That being said, how can I tell what gears are in my rear-end? (I know I am leaving myself wide open for "rear end" jokes, but I'm willing to take the risk.) Is it listed somewhere? Something to look for in physical design? I am at a loss. I had read a few places on the net that some people were seeing good to better MPG with 3.08 (?) gears in their Ford Rangers. Mine is a 2.3L with a 5-speed manual w/OD. Is there any truth in there? Maybe that's what I have now, I don't know. I see great mileage, but there is always room for improvement. My little Ranger see about 80% highway and the only real in-town driving is short trips to run errands.
Thanks for the help.
Old 09-08-2010, 07:13 PM   #2 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
I have 2.8's in my diesel suburban but thats an 8 banger, not a ranger.
Generally speaking higher gears give higher FE, but only if you keep your foot out of it ESPECIALLY in 5th, you need to downshift to conserve FE if you actually end up overgeared but a ginger driver can take advantage of gears higher than the vehicle can realistically tolerate by not overloading the motor at low RPMs.
Good Luck
Ryan
Old 09-08-2010, 07:18 PM   #3 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
Usually, US axles have a little sheetmetal tag held on by ine of the cover screws. But these often are gone on older vehicles.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 09-08-2010, 07:21 PM   #4 (permalink)
rmay635703's Avatar
Ah yes re-reading GM vehicles have codes inside the glove box that you can have your dealer look up, the serial and whatnot can get your dodge dealer to give you a build sheet. Now ford, I have absolutely no idea, never did one.
I will say that if you turn the propshaft with the wheels in the air you can count place a timing mark on both and count out the gear ratio, not fun but doable
Cheers
Ryan
Old 09-09-2010, 12:31 AM   #5 (permalink)
oldschool
Olympiadis's Avatar
White2003Focus - '03 Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Irocz LB9
Last 3: 30.14 mpg (US)
Ford Ranger Axles - The Ranger Station
I think most of the 4-cylinders got the 4.10:1 ratio, 3.73:1, or 3.55:1 ratio rear gears, but it's always best to check.
You can usually determine it by using the conversion formula for engine speed vs vehicle speed in your 1:1 gear.
RPM = ((MPH * (rear ratio * 336)) / (tire diameter in inches)
The Following User Says Thank You to Olympiadis For This Useful Post:
hat_man (09-09-2010)
Old 09-09-2010, 09:32 AM   #6 (permalink)
The Truck - '06 Silverado Ext Cab 4x4
One way to check is to use a friend and a piece of chalk.
On a flat straight surface like a parking lot or driveway mark the rear tire at the ground and put a mark on the rear driveshaft and axle housing where the driveshaft attaches.
Then drive slowly forward or backward and have your helper count the number of times the driveshaft rotates during one revolution of the tire.
The Following User Says Thank You to Fubeca For This Useful Post:
Old 09-09-2010, 11:38 AM   #7 (permalink)
Phantom's Avatar
Bonnie - '98 Bonneville SSE
3800
90 day: 26.91 mpg (US)
Use the site that Olympiadis listed or check Ranger & B-Series - Ford Truck Enthusiasts Forums almost all cars you can search for the RPO codes online to get all the info on what was included on the car.
RPO Codes.com- GM option codes,GM rpo codes,Regular Production Options
OptionCodes.com- Ford, Chrysler option codes lists
I move at the speed of awesome.
Old 09-09-2010, 11:44 AM   #8 (permalink)
90 day: 28 mpg (US)
Thank you all for the advice. I am going to try the chalk method this weekend. (Thanks Fubeca)
I do drive pretty light footed especially on the highway. Usually only giving it just enough right foot to keep moving at 55. In town I don't even use 4th gear. 1st thru 3rd to get up to 30-35 then 5th (O/D) to maintain it.
Rmay- This may sound silly but, can you explain what you meant by "a ginger driver can take advantage of gears higher than the vehicle can realistically tolerate by not overloading the motor at low RPMs." Does this mean I might have a more difficult time driving in-town at lower speeds/rpms? Without a tach I can only guess what kind of rpm's I am turning at 55mph but I would think around 1600-1800. That's just a guess though. In-town at 35mph in 5th gear I wouldn't have a clue.
After checking the great link from Olympiadis (Thanks) it seems I have an open 7.5" rear end with 3.73 gears. There are two other gearings listed lower than mine. (3.45 and 3.08) I wonder if either of these two would be beneficial to me. Any thoughts?
Thanks again for all the advice.
Old 09-09-2010, 03:22 PM   #9 (permalink)
comptiger5000's Avatar
The Beast - '98 Grand Cherokee (ZJ) 5.9 Limited
90 day: 14.58 mpg (US)
What he means is that getting on it too hard at low rpms is just as bad as having higher rpms. There's a balance between gearing, engine and driver to be struck.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 09-09-2010, 03:37 PM   #10 (permalink)
90 day: 28 mpg (US)
I think I see what you mean. I'm pretty lightfooted in-town also. It's pretty evident from the annoyed looks from the drivers behind me. 30-35 mph in-town in 5th gear when everyone else is in such a hurry. I love pulling up to them at the stoplights after they go roaring past.
Aerodynamic lift- A real problem Hermie Aerodynamics 175 12-05-2010 07:56 PM
Drag Racing Aero Help Bennett_Racing Aerodynamics 33 06-28-2010 06:02 AM
extending rear bumper end caps on a 08 liberty rav Aerodynamics 1 02-09-2010 08:18 PM
Noisy rear end problem in the Previa. orange4boy Off-Topic Tech 4 09-03-2009 04:19 AM
tigra AERO PROJECT rear end question fabrio. Aerodynamics 19 03-31-2008 12:01 PM
