Old 12-09-2009, 06:06 AM   #11 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by Old Tele man View Post
...tire "hysteresis" is a function of rubber flexing upon contact with the road, then compressing under weight, then un-flexing upon release from the road.
...that's *why* an older, well worn tire has a lower rr value than does an identical brand new tire.
Hysteresis is the amount of heat generated for a unit volume of rubber doing a unit of flexing. Think of it as internal friction.
And since there is less rubber in a worn tire, that's why worn tires have lower RR than new tires - everything else being equal.
The Following User Says Thank You to CapriRacer For This Useful Post:
rgathright (12-09-2009)
Old 12-09-2009, 09:00 AM   #12 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...heat is a byproduct of hysteresis, not the other way around, because hysteresis is the "lagging" of stored energy behind its causing force.
...examples of hysteresis are: tires, transformers, magnetic recording, magnetic amplifiers.
...just about anything that deforms but doesn't exactly return to its pre-deformation characteristics, ie: less than 100% energy IN to energy OUT ratio...with some manner of intermediate energy "storage."
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
Old 12-09-2009, 11:31 AM   #13 (permalink)
Tire Geek
CapriRacer's Avatar
Ok, OK, but we do agree that it's the amount of rubber (and not the hysteresis) that causes the change in RR between new and worn tires, right?
Old 12-09-2009, 04:03 PM   #14 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
Sorry, but sidewall stiffness hardly enters the equation when it comes to RR.
RR is pretty much all about the tread compound - how much, what kind, how much deflection (basically inflation pressure). You just can't escape the Wear / Traction / RR triangle.
Barry's Tire Tech
Thanks for straightening that out for me
I thought that was because an old tire is smooth, while a new one has a more "knobby" tread, like a mountain bike tire.
Piwoslaw's Peugeot 307sw modding thread
Old 12-09-2009, 05:37 PM   #15 (permalink)
...beats walking...
...when a rubber knobby is bent over, it absorbs energy, but when it's released from being bent over, not all of the energy is returned as "springy-ness" in the rubber, but rather is wasted as heat.
...less rubber to absorbe energy = less energy stored, and thus less energy not being returned and ending up as wasted heat.
...some of the newer "tread" designs incorporate "deflection bumpers" in between the rubber block pieces to lower rubber-on-rubber contact which is purely "heat-generating."
...here's what Consumers Report says: "...As tires wear out, you’ll likely see improved fuel economy since the tires will have less rolling resistance as the tread (mass) is removed from the tire. Installing new tires, identical in brand and model as those removed, and you likely see a reduction in your fuel economy."
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 218 12-11-2008 10:21 PM
New Wheels & Tires trikkonceptz Success Stories 9 11-03-2008 02:05 PM
News: Under-inflated Tires Waste 5.3B Liters of Fuel/Year in Europe MetroMPG General Efficiency Discussion 3 03-06-2008 10:23 PM
