Old 12-07-2009, 07:55 AM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
"Green" tires to be standard in Europe by 2012
This is based on another article from the eco-issue of Auto Motor i Sport (2/2009).
The European Union is reducing CO2 by setting limits for the automotive industry. In order to raise fuel efficiency (and lower CO2 emissions) the car companies will have to switch to "green" tires with lower rolling resistance. In fact, the EU has mandated that all new cars in Europe be sold with eco-tires in 2011, and all new aftermarket tires must have lower rr in 2012. To aid customers in choosing best tire, they (tires, not customers) will have tags that help compare their rolling resistance, grip and noise. The tags are similar to ones that can be found on all household appliances sold in Europe, stating their energy (and sometimes water) comsumption class. Unfortunately, which class the tire falls into will be solely up to the manufacturer. This shouldn't worry us with tires from well-known producers, such as Michelin whose been selling lrr tires since 1992, but could be a problem with cheap tires from China.
Piwoslaw's Peugeot 307sw modding thread
Old 12-07-2009, 11:13 AM   #2 (permalink)
JonnyG's Avatar
97RAV - '97 RAV4
90 day: 22.97 mpg (US)
Is there going to be an exception in certain countries for winter tire use during certain months?
Old 12-07-2009, 01:41 PM   #3 (permalink)
Ohh snap
brucey's Avatar
Lesbaru - '00 Outback
90 day: 21.98 mpg (US)
Convertalier - '00 Cavalier Z24 Convertible
90 day: 26.08 mpg (US)
Send a message via AIM to brucey
It's my understanding you can get low RR snow tires that perform excellent already. The Hakka R's come to mind.
Daily Driver
Winter Beast
Old 12-07-2009, 01:45 PM   #4 (permalink)
JonnyG's Avatar
97RAV - '97 RAV4
Oh I didn't know that. I'll have to look into those for myself.
Old 12-07-2009, 01:46 PM   #5 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Are they using standardized testing for the tires now? Last I hear, Crr testing was completely up to the mfg and they all do it differently.
Old 12-07-2009, 07:32 PM   #6 (permalink)
Is there going to be an exception for track or autoX tires?
Old 12-08-2009, 01:03 AM   #7 (permalink)
aero guerrilla
Piwoslaw's Avatar
Diesel
I think the testing is still up to the mfg, but there are some independent institutes that may check it (and EcoModders as well ). There will be more testing and checking as this starts to get more and more important.
I don't know anything about track or 4x4 tires.
I've noticed that most articles on low rr tires (including this one) comment that lower rr reduces grip and braking efficiency, but only once have I read that those are two different animals: Rolling resistance is mostly from the tire wall flexing, while grip depends mostly on the type of rubber used in the tread. Of course, tread pattern has an effect on both, and decreasing sidewall stiffness can improve grip while increasing rr. If a tire is reengineered to have a stiffer sidewall, good tread pattern and soft rubber tread (all in the right proportions), then it will have lower rr while retaining safety and handling parameters.
Or you can just pump your tires and drive slower
Old 12-08-2009, 06:38 AM   #8 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by Piwoslaw View Post
........I've noticed that most articles on low rr tires (including this one) comment that lower rr reduces grip and braking efficiency, but only once have I read that those are two different animals: Rolling resistance is mostly from the tire wall flexing, while grip depends mostly on the type of rubber used in the tread. Of course, tread pattern has an effect on both, and decreasing sidewall stiffness can improve grip while increasing rr. If a tire is reengineered to have a stiffer sidewall, good tread pattern and soft rubber tread (all in the right proportions), then it will have lower rr while retaining safety and handling parameters.
Sorry, but sidewall stiffness hardly enters the equation when it comes to RR.
RR is pretty much all about the tread compound - how much, what kind, how much deflection (basically inflation pressure). You just can't escape the Wear / Traction / RR triangle.
Barry's Tire Tech
The Following User Says Thank You to CapriRacer For This Useful Post:
Piwoslaw (12-09-2009)
Old 12-08-2009, 09:06 AM   #9 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...tire "hysteresis" is a function of rubber flexing upon contact with the road, then compressing under weight, then un-flexing upon release from the road.
...that's *why* an older, well worn tire has a lower rr value than does an identical brand new tire.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
The Following User Says Thank You to Old Tele man For This Useful Post:
Old 12-08-2009, 10:31 AM   #10 (permalink)
Black Beauty - '09 Accord EX-L
90 day: 27.44 mpg (US)
Green tire regulations will mean more advances for us as well.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 218 12-11-2008 10:21 PM
New Wheels & Tires trikkonceptz Success Stories 9 11-03-2008 02:05 PM
News: Under-inflated Tires Waste 5.3B Liters of Fuel/Year in Europe MetroMPG General Efficiency Discussion 3 03-06-2008 10:23 PM
