Old 02-08-2015, 04:20 PM   #1 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Grochu modding thread - eco gasser (image heavy)
Hi Guys,
This is my new thread about modding my Polo 1.4
I've worked on it recently and the plan was to install MPGuino and kill/start switch. Here are the results.
First thing was to tear apart the dash to get access to the electric harness.
Then I've installed some cables for MPGuino feed and the kill switch.
Injector signal cable
Kill switch relay - it's cutting hall sensor signal
Since my gear shift knob was made of aluminum it was almost impossible to cut the hole for the kill switch. I wanted to put it the same way as I've made it in Berta
I needed to fabricate a new knob. I used a piece of oak wood (that is over 80 years old!)
Fabrication process:
Kill/Start switch and the knob finished
Finally I was able to install MPGuino:
If you wonder where is my radio
On the outside of the car first thing I just needed to do was to limit the air going through the engine bay:
Just a duct tape, some pipe insulation and stainless steel wire mesh
That's all for now. More to come soon (hopefully)
Now I need to calibrate MPGuino
ID:	16956   Click image for larger version
ID:	16957   Click image for larger version
ID:	16958   Click image for larger version
ID:	16959   Click image for larger version
ID:	16961   Click image for larger version
ID:	16962   Click image for larger version
ID:	16963   Click image for larger version
ID:	16964   Click image for larger version
ID:	16966   Click image for larger version
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following 6 Users Say Thank You to AndrzejM For This Useful Post:
Bataleon (06-06-2015), HyperMileQC (02-09-2015), iveyjh (03-09-2015), Joggernot (02-09-2015), niky (03-09-2015), OG VX (02-09-2015)
Old 02-08-2015, 08:12 PM   #2 (permalink)
Nice work on the shifter knob and kill switch.
AndrzejM (02-09-2015)
Old 02-09-2015, 05:54 AM   #3 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
VW sure have a habit of making things easy to work on, don't they?
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
OG VX (02-09-2015)
Old 02-09-2015, 06:53 AM   #4 (permalink)
AndrzejM's Avatar
Sure they do But I've seen worst too
Old 02-09-2015, 07:12 AM   #5 (permalink)
AndrzejM's Avatar
Kill switch details:
I just cut in the signal wire between the hall sensor and ECU. Relay is controlled by the switch on the gear shift knob.
Start switch details:
Start switch on the knob controls the relay that is connecting wires that are going from the ignition switch.
ID:	16973   Click image for larger version
Last edited by AndrzejM; 02-09-2015 at 07:38 AM.. Reason: Error in one of the diagrams
The Following User Says Thank You to AndrzejM For This Useful Post:
oldtamiyaphile (02-09-2015)
Old 02-09-2015, 07:30 AM   #6 (permalink)
JDM hypeR mileR
OG VX's Avatar
The OG VX - '92 Honda Civic VX
90 day: 68.64 mpg (US)
Awesome build so far! I, too, love the shift knob.
Keep us posted!
"Yesterday as I was going in to the shop, I came upon a recently killed Armadillo in the middle of the road with one front leg sticking up. As I passed over him he "High Fived" my air dam. I thought that showed a great attitude on his part." -The Donkey CRX
The Following User Says Thank You to OG VX For This Useful Post:
Old 02-09-2015, 12:42 PM   #7 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
Nice job on the wiring and shift knob! I really like the VW Lupo and Polo models. Since your previous builds were really well done, I'm sure this one will be great too!
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
The Following User Says Thank You to HyperMileQC For This Useful Post:
Old 02-09-2015, 02:51 PM   #8 (permalink)
AndrzejM's Avatar
First ride behind me. MPGuino needs calibration - definitely, because readings are way off. All other things works flawlessly. Kill switch and start switch works just great, but knob needs some work though... It's a bit to big and I want it to fit my hand as it should.
Thanks for the kind words.
Old 03-09-2015, 07:34 AM   #9 (permalink)
AndrzejM's Avatar
On last Monday I got info, that i need to go to Prague. My car was still in pieces, so on Monday evening I needed to put it back together and make some changes I've planned.
Anyway I've managed to fix everything inside the car and to work a bit on the front.
Duct tape comes in handy, as always. Upper grill block:
And then I've managed to make an air dam. I had a rear bumper cover from Opel Corsa, that I got from a local junkyard.
I cut it in half, frlipped over and voila, an air dam
I've used lots of rivets, some stainless steel mesh
I know it looks like a bodywork by Freddy Krueger, but it works pretty well.
On my way to Prague and back I've managed to squeeze out 1129km from relatively small tank with an average FE of 3.83 l/100km (61.41 mpg US)
Not bad IMHO
More changes to come...
ID:	17144   Click image for larger version
ID:	17146   Click image for larger version
BabyDiesel (03-09-2015)
