Old 02-21-2008, 11:24 PM   #1 (permalink)
Ninja Tornado
RH77's Avatar
Teggy - '98 Integra LS
90 day: 35.44 mpg (US)
Heated Washer Fluid
In full-disclosure: I rent a lot of different cars for work -- lots of travel.
I requested an "Economy" car and ended up with a Buick Lucerne CXS V-8. Ugh.
Confessions of a Buick Driver...
The agency was thin on vehicles and offered either a Toyota Tundra Pickup or the Buick Whatever. The Car sounded like the efficient option...
Some insight on the situation:
The vehicle is loaded with feature content, one of which is Heated Windshield Washer Fluid.
From an efficiency and not luxury standpoint, I can see this helping retain heat to the windshield during those freezing rain and snow situations while driving the average vehicle.
For those who drive in cold, road-spray situations or freezing rain and snow, it is common to divert a LOT of heat to the defroster/windshield air flow to keep the windshield surface liquid and not frozen (critical for vision). Coolant heat is lost, efficiency could decrease...
Hypothesis: a small electric heater warms the washer fluid to avoid coolant temperature loss, and is more efficient (depending on alternator load).
Any thoughts? I know it's a stretch, but brainstorming could produce some interesting conclusions...
RH77
_______1998 Acura Integra 3-Door, Automatic _______
Old 02-22-2008, 12:45 AM   #2 (permalink)
Who
UnderModded
Pablo - '07 Santa Fe AWD
90 day: 23.62 mpg (US)
Any thoughts?
Albeit trivial, the Lucerne was the last Buick that Joel Piaskowski designed while at GM. He left there and joined Hyundai and designed the Santa Fe that seems rather Buick like to me.
Old 02-22-2008, 01:10 AM   #3 (permalink)
Ryland's Avatar
Tomos Arrow - '05 Arrow ST
90 day: 101.68 mpg (US)
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
are the heaters on the washer jets electric, or are they heated off the coolent?
Old 02-22-2008, 01:19 AM   #4 (permalink)
ECO-Evolution
Lazarus's Avatar
Days of Yore - '98 E-Bike
90 day: 4979.53 mpg (US)
You could just put this stuff in there.
CE FREE was developed with NASA-based technology to provide protection from ice in temperatures down to -20° F.
No I believe you, just show me a source please
Old 02-22-2008, 01:26 AM   #5 (permalink)
Ninja Tornado
RH77's Avatar
Ah, even better -- Chemistry vs. Thermodynamics (roughly).
Also, I'm not sure how the fluid is warmed -- as I used it, I recall stories of people not used to ice, throwing hot water on the windshield to thaw frozen precipitation -- the result -- cracked glass.
It can't be much of a warmup -- probably 70-80F. When the button is pressed, there's about a 10-second indicator: "Heated Windshield Wash Wipe Pending". Then it automatically sprays and wipes.
It makes a great way to chip away at ice/snow without starting the vehicle.
I'm sure the solvent method works similarly...
RH77
Old 02-22-2008, 02:21 AM   #6 (permalink)
Peakster's Avatar
'93 Cherokee - '93 Grand Cherokee
90 day: 13.24 mpg (US)
I had a Canadian Tire Motormaster "HotWash" heater for my car's wiper fluid and it worked very well. I put in summer fluid too early in spring and the freezing caused the mechanism to crack and be junked.
When it was working, I could feel the added electrical load on the engine.
Here's a recall for the device: http://www.cbc.ca/consumers/market/r...08mar2006.html
Old 02-22-2008, 08:55 PM   #7 (permalink)
The often used method for the prevention of freezing washer fluid is to add alcohol.
Unfortunately the stuff does evaporate so the mix changes over time and the problem of freezing jets still exists.
Maybe siting the fluid container near the exhaust would help?
Pete.
Old 02-22-2008, 10:39 PM   #8 (permalink)
fanamingo's Avatar
fanamingo's Civic - '07 Civic LX
90 day: 39.12 mpg (US)
I think the electric heater approach would be less efficient than a standard defroster. The fluid would lose a fair bit of heat to the outside air. However, if you encounter a situation where the defroster isn't up to the task, supplemental warmed washer fluid could do the trick.
Video: We're not the only mammals to play with fluid dynamics MetroMPG Aerodynamics 4 02-14-2008 09:38 PM
Drag Optimization of Light Trucks Using Computational Fluid Dynamics bondo Aerodynamics 16 01-21-2008 06:36 PM
My kingdom for a giant, heated workspace MetroMPG The Lounge 13 01-07-2008 12:11 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
