Old 08-04-2008, 09:01 PM   #1 (permalink)
EcoModding Tinkerer
Question Honda Insight - Replace CVT Transmission (with manual)
I'm considering buying a Honda Insight CVT. Does anyone know if the CVT can be replaced with a manual transmission from another Honda Insight? Thanks.
Old 08-04-2008, 11:15 PM   #2 (permalink)
Red
Red's Avatar
Fish - '02 Sebring LXi
Send a message via MSN to Red Send a message via Yahoo to Red
You could, you'd need a few parts which isn't easy to find for an Insight
For starters
ECU
Cluster
Shifter
Shift cables
Trans
Flywheel
Clutch
Trans sensors (5ish or something)
Part of the harness that hooks up to those sensors
And since you'll be swapping in a manual trans ECU might as well hook up the Lean Burn stuff so
LAF sensor
New cats with the right ports
Extra bits of harness
IMO too much work and $$ to be worthwhile unless you have most of the stuff on hand or you could pick up a parts car cheap
Old 08-05-2008, 07:01 AM   #3 (permalink)
EcoModding Tinkerer
Thanks for the information. That's quite a laundry list of parts. I had a feeling it might not be worth the effort, but I'm glad I asked.
Old 08-05-2008, 09:16 AM   #4 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
Why would you want to change it? Isn't CVT the ultimate in efficiency? Your engine can always choose to be at the most efficient RPM for any cruising speed, and select the most efficient RPM for any acceleration rate... I guess they just havn't set up the computer control to do that?
Old 08-05-2008, 02:31 PM   #5 (permalink)
Red
Red's Avatar
On the Insight the CVT isn't all that reliable. Nor does it comes with Lean Burn. Other than that for an engine like the Insight a CVT would be a good match provided it could keep the RPMs up while driving especially during a shift. The gears on the 5spd are so widely spaced that you drop out of the power band each shift
Old 08-05-2008, 02:45 PM   #6 (permalink)
Brown Bus - '98 Sonoma X-Cab SLS
90 day: 31.37 mpg (US)
The jeep I recently rented with a CVT displayed a major efficiency advantage. It was able to lock the torque converter out as soon as the vehicle got moving.
However, it didn't really get that good of mileage anyway. Some suspect that the hydraulic pumps that they require eat a bunch of power.
Meh Truck
Old 08-05-2008, 02:52 PM   #7 (permalink)
Originally Posted by Red View Post
...for an engine like the Insight a CVT would be a good match provided it could keep the RPMs up while driving especially during a shift.
CVT = no shifting.
Old 08-05-2008, 03:09 PM   #8 (permalink)
Red
Red's Avatar
Originally Posted by MazdaMatt View Post
CVT = no shifting.
Yeah I miss worded my post. What I meant to say was that since a CVT doesn't shift you don't get the RPM drop you see with the 5 spd and it makes it easier to drive
johnmyster, did you drive a Compass?
Old 08-05-2008, 06:07 PM   #9 (permalink)
Yup. A rental AWD Compass. Slow as turd. 26 mpg highway.
Meh Truck
Old 08-05-2008, 06:24 PM   #10 (permalink)
When I was looking for a decent 3 cylinder 5spd 1995-2000 Metro, I came a cross several Lsi's that were perfect except they were automatics. I went through the same thought process, concluded a trans swap just wasn't worth it for a Metro... unlike the Insight, Metro donor cars are plentiful
Reviving a 2000 Honda Insight "beater" Red Hybrids 209 05-07-2012 09:47 AM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 04:04 AM
Auto transmission with the manual shift feature ScottC33 Hypermiling / EcoDriver's Ed 5 06-17-2009 07:32 AM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
Honda insight, doing research, interesting trends NoCO2 General Efficiency Discussion 15 05-06-2008 07:36 PM
