Old 02-26-2016, 05:06 PM   #1 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
??? How to drive a single rear wheel on a front wheel drive car
I have been toying with this idea for a long time and really don't see any way to do it with off the shelf. (aka drive a rear wheel on a fwd car)
My hope was to find a way to get a halfshaft on a dummy rear axle so I could then drive it from something.
Hub motors won't work (1800lbs/4 causes rapid failure)
I really don't want to jack up the car a foot to fit in a straight axle.
Anyone have any good ideas what might be able to accomplish this without rapid failure?
Thanx
Ryan
Old 02-26-2016, 05:36 PM   #2 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Your question is kind of confusing me. Are you wanting to turn a 4 wheel car into a 3 wheeler? And use the car's engine to drive the rear wheel? If so, I'm thinking you are going to need the back end of a motorcycle, shaft drive might be a good idea or a sprocket on the driven axle of the trans for chain/belt drive.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 02-26-2016, 06:16 PM   #3 (permalink)
I have been pondering the same thing for years... and not come up with anything that doesn't require a bunch of cutting and fabrication.
Except if you start with an AWD Tempo!!! Very nice li'l IRS half-shaft set-up. Except none of my fleet of Tempos is AWD. Come to think of it, all I'd probably need to get is the rear carrier bearing and half-shaft for one side and it should bolt right in! And it wouldn't need any of the other AWD stuff anyway. Hmmmmm.
I suppose any little AWD car would give a tremendous head start on such a project.
Old 02-27-2016, 11:29 AM   #4 (permalink)
rmay635703's Avatar
Frank is right on,
I am not looking to do either of the things you mention.
I am looking for a better way to integrate mild hybrid activity into a front wheel drive car by driving a rear wheel. The way I have seen done is to use a 5th wheel off a trailer hitch, interesting but not reliable enough for me.
The motorcycle idea is interesting but I don't really have a safe method of placement for the drivetrain forward or behind the wheel, also a motorcycle would cause the wheel to be floating, it wouldn't be stablized in terms of yaw as well as I would like.
Ah well, one guy has rebuilt a chinese hub motor into something almost usable, but he uses it off a half shaft as the bearings even when rebuilt are up to bouncing on a wheel.
If anyone can solve this problem I think we are in the golden era of conversions from junkyard parts, just don't realize it yet.
Cheers
Ryan
Old 02-28-2016, 10:09 AM   #5 (permalink)
Interesting idea, can't wait to see what we all come up with.
Old 02-28-2016, 10:57 AM   #6 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
I think Frank is on the right track with using an AWD car or one that could have had AWD (maybe even another model based on the same platform). You could even use the rear diff for gear reduction and to drive both rear wheels.
Camry Thread
E-Bike Thread
Old 02-28-2016, 11:32 AM   #7 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Ahem....
I'll just leave this here. Turn Your Car Into a Plug-In Hybrid for $3,000 | WIRED
Old 02-28-2016, 03:54 PM   #8 (permalink)
rmay635703's Avatar
Originally Posted by ksa8907 View Post
Ahem....
Yeah, I have seen things like that for years but its just another variation of a hub motor, you've got grime and vibration to deal with, copper wire connections don't deal with that type of thing very well.
Add to that the bearing wear out much more rapidly, even on rear now steering wheels.
If they could move the motor in so it wouldn't be suspended then they might have something
Even if it was in slightly it would still be less direct impact than in the hub it would be better.
Ah well.
Old 02-28-2016, 11:58 PM   #9 (permalink)
I think if you got the rear drive and suspension out of an SUV or cross over that would be a great start.
One that has available aftermarket gear ratios would be a plus.
Old 02-29-2016, 11:22 AM   #10 (permalink)
Dark Egg - '12 VW Touraeg
And early AWD Dodge Grand Caravan. Seems you wouldn't have to start with an AWD model just use a normal version and get the rear suspension out of the junkyard. Then lose thar big center diff and put a motor there. There will also be plenty of room for a large battery pack.
