Hi,
I have plans to make A-B-A test to FleXcaps following the instructions on this topic:
http://ecomodder.com/forum/showthrea...ery-11445.html
- Test will be made at dark, when there is less to none traffic and weather changes are not that big
- On motorway
- Cruise control speed 86 km/h
- On level straight road test length about 2-5 km
- Choose non windy day from forecast reports
- Make about 20 tests so 10 A and 10 B
- If there is lots of variation between runs, even more
I dont know will this fit that topic or should we have own topic on test documentation. Mods can decide. I will first put this as own topic.
Anyway I want the documentation to be as "bulletproof" as possible. What I will do:
- Measure windspeed between every run
- Measure temperature between every run
- Put chapter for notes if there has been something that may have effected the results. Car that you can see in front or back of you etc.
- Will make a test video to show the test procedure and conditions. One take on each A and B versions for full test length. Show how the changes has been made. Shoot some nice drive by footage. Other video footage that will affect the results will be done separetely from the tests, like drive pass the truck filming the same time...What else?.
- Report as precisely the equipment used
- Show the raw data on my webpages so dont hide them from public.
Make some A4 for all these procerdures which can used in all tests and will be available for everyone.
After tests make some nice charts and plots from the data, for commercial use. Always have link to the actual test data and procedures used.
Am I missing something out?
