10-25-2012, 02:57 PM
#11 (permalink)
Acetone belongs at the unicorn corral.
To make a fuel that improves MPG you have to increase the heat content. As a rule, heat content goes up as one moved down the distillate column. Kerosene and diesel have more heating value than gasoline, but they reduce the octane of the gas.
Now a Super Cub does not have all that high a compression, so you probably can lower the octane a bit and still run.
I'd suggest removing the fuel hose from your tank and try mixes of kerosene and gasoline. Use regular unleaded as a base. Regular has (slightly) higher heating value than premium.
Kerosene won't stink like diesel. at one time U-boats ran on spark ignition engines that were fueled by kerosene.
Start with a 5% kerosene/95% RUG by volume mix. Rig up a temporary test tank to hold a cup or so of the mix. You don't want to mix up a lot until you figure what your final mix will be. Once its in the carburetor, start it up,and see how it runs.
If it runs make up some 10% kerosene mix. Repeat until the engine won't run on the mix. Clean out your carb and back down to the last mix that ran.
Make a gallon of mix and put it in the gas tank and ride the bike around, to see how it runs under load. If it knocks, back down some more.
Kerosene will make it harder to start as the vapor pressure is much lower than that of gasoline. In the cylinder, the gasoline flame is blow-torching the kerosene into combustion. You might want to go to a hotter spark plug.
You'll undoubtedly need a "leaner" mixture to have enough air for combustion. If it makes black smoke, you're too rich.
My guess is you can probably run 25% kerosene.
Heat value for kerosene is about 135,000 BTU/gal.
Heat value for RUG is about 120,000 BTU/gal.
So the heating value of a 25% kero mix would be about 124,000 BTU/lb or about 3% higher than for RUG.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
11-02-2012, 05:24 AM
#12 (permalink)
^^ Good idea, I never thought of this. I think I'll give it a try, although unfortunately for me, it's a little harder to find kerosene. I don't mind the smell, a lot of things really stink over here anyway so I think I'll give the mixing process a try with diesel oil.
As for other suggestions, I tried the 640:1 mix for 1 liter but my mpg stayed exactly the same as with straight petrol, about 220 mpg. I can see how it's possible how it might help out a diesel like my Hyundai though.
With a 200:1 mix it goes to about 235, and a 100:1 mix I am around 240-50. 2 stroke oil that is. I have the same commute everyday so it's easy to compare mileages.
Another question, since the kerosene/diesel takes energy from the petrol's flame front to combust, is it same to say that it can act as a detonation suppressant? Or would the diesel, since being a "lower octane fuel" create a condition more prone to detonation?
Thanks all so far!
1988 Honda Super Cub 50cc
11-02-2012, 01:11 PM
#13 (permalink)
diesel does not combust / at all in gas engines
mixed at
2oz per gallon
diesel does not combust at all in a G10 Geo metro engine , i have proved this using scopes and the 02 sensor waveform and
fuel trim values
fuel trim goes to heavy subtract as athe UN burned diesel
combustibles
gets into the exhaust stream causing the ECM to incorrectly believe that the system is rich , so the ECM subtracts fuel
the engine runs poorly and you can smell the unburned diesel
FE goes down
i still have the files -
but most will not know what they are seeing
the mortals in another forum had no clue
i can post a KISS file
11-02-2012, 01:30 PM
#14 (permalink)
DieselMiser
You could always try adding nitroglycerin to gasoline like Jerry Lewis's character in "The Nutty Professor"
11-02-2012, 04:15 PM
#15 (permalink)
...beats walking...
As the hydrogen content goes UP so does the energy content.
11-02-2012, 11:11 PM
#16 (permalink)
I just read about the octane rating of diesel and am going to pass on mixing it or even trying. Sure, high flash point, but I am not willing to drop my octane rating that low, even in a very low compression engine like my Honda.
I think serious that I am just going to keep adding 2 stroke oil to keep it leaning out and then occasionally blast it with some water up the intake to decarbonize it. Then when I figure a more sophisticated way to do an experiment, I'll give it a go.
11-03-2012, 08:03 AM
#17 (permalink)
EcoModding Alien Observer
Saint LaPointe sez....
There is an important chore by the fuel in preventing combustion from becoming too fast during the early first stage after the spark has started the burn or after the diesel fuel is injected. Gasoline is designed to not burn too quickly while diesel fuel is designed to ignite as soon as possible without lag or with a very short lag time. When gasoline burns too easily, there is knock near TDC. When diesel fuel burns too slowly, there is knock near TDC. Knock is the general category for abnormal combustion, such as detonation (with gasoline) and fuel knock with diesel fuel. When fuel burns uncontrollably, pressure piles up on top of the piston near TDC where the excess pressure cannot do much to turn the crank and make torque. Plus this condition causes damage to engine parts and is inefficient as well. It seems the engine gets the longest life from its parts when it runs most efficiently and yields the best mileage. Runaway combustion happens from a bad combination of fuel components for the application. BTW there is a weird spark plug being promoted in Detroit that claims to ignite all the fuel and air in the chamber in a single (instantaneous) burst at TDC thereby creating enormous efficiency and economy. Yeah, right.
With gasoline we seek a gradual flame propagation from spark ignition in first stage and rapid propagation in second stage. With a diesel we seek rapid flame propagation in both first and second stage. The diesel fuel is supposed to ignite immediately as it gets squirted into the hot cylinder. That is what we mean by compression ignition. The combustion is regulated by the rate of injection from the pump and injectors while the piston is moving down. With gasoline the rate of combustion is regulated by a kind of "peeling the banana" effect whereby outer layers of more stable ions are stripped from the rather large original fuel particles by the violent collision process. These initial particles combust somewhat gently even at the high temperature and pressure near TDC. The burn is controlled by peeling the banana and uncovering faster burning fragments under the top skin. Then more peeling reveals very fast burning Freds that urgently seek any Opel to mate with in the scarce condition part way down the cylinder where fewer and fewer free Freds and free Opels can be found. Any aid that could assist combustion in that part of second stage will be very welcome indeed because that is where many engines and fuels go wrong. That is where they allow combustion to peter out, even well before the exhaust valve opens. In gasoline engines, we need to get maximum pressure to occur at about 15-20 degrees past TDC. In diesels, we will see a "constant" pressure from about 15 to 75 degrees after TDC. Gasoline combustion is termed "constant" volume while diesel combustion is termed "constant" pressure. The quotes mean it is ideally constant, not actually.
You can appreciate that diesel fuel is not as complex as gasoline which consists of hundreds of ingredients that contribute to a very carefully designed layered burn scenario that we commonly find available in three different grades of octane rating. Too much octane rating and the burn may be slow while too little octane rating and the burn may proceed too quickly from lack of tolerance for heat and pressure. Altitudes affect the rate of burning as atmospheric pressure drops and we need a lesser octane rating in the mountains. Superchargers raise the demand for higher octane because of the higher intake pressures from the blower. To protect engines from knock, electron absorbers are put into gasoline--such as metals or fuel additives with a lot of methyl ions such as xylene, toluene, acetone, neopentane or neohexane--my choices. These additives and methyl ions add a great deal of vaporization to the fuel and that in turn can create cooling due to the latent heat of evaporation. IOW evaporation and vaporization cool the mixture as larger Fred fragments are allowed to form into many small fragments and improve efficiency. It takes energy to force the breakup. That energy comes from the linear and spin kinetic motions of the particles in the furnace. So cooling occurs and the mix is less likely to detonate and will in fact allow a smoother operating, more efficient engine.
Octane and speed of combustion are only superficially related. Octane rating is best seen as the tolerance for heat and pressure of a fuel. Octane rating is NOT a simple reference to the speed at which fuel propagates a burn because that speed is never a constant but always very different and random.
When good fuel layering exists and combustion progresses nicely, most if not all of the fuel in the cylinder gets burned and the specific fuel consumption rate is the lowest possible--perhaps below .400. Average good gasoline is .500. When fuel layering is poor and combustion falters part way through the burn, the specific fuel consumption rate is very high--perhaps over .700 as may be the case with ethanol blends. When atomic hydrogen or CH particles are peeled or released too soon, an explosion could be triggered and the engine might ping like the old cliche--an ashcan full of marbles. Hydrogen gas burns 8-10 times faster than gasoline which makes for many headaches of engine design. Each hydrogen molecule or H2 has absolutely no layering and resembles a naked stick of dynamite with a microscopic fuse. Hydrogen is an ideal fuel for fuel cells and rockets rather than internal combustion engines.
There was a temptation to employ large and heavy fuel molecules as mileage fodder. Heavy molecules yield more BTU when they burn and can give a longer range. However they might be sensitive to cracking in the chamber and might produce undesirable products (such as heavy alkanes that refuse to disassociate) during the peeling, may cause detonation and/or create sludge and varnish problems in the engine. They are okay for asphalt. The fuel student must know his stocks intimately and have tested the components carefully in the lab before selling the stuff. During the fuel crisis of 1973, many bad gasolines were thrown out into the street.
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
11-03-2012, 08:15 AM
#18 (permalink)
A mix that might work?
Notice that this uses BOTH diesel and acetone...etc...
.66 oz SI-1, 2.5oz acetone, 1oz xylene, 1oz #2 diesel fuel, and 1/2 oz of synthetic motor oil, per ten gallons of gasoline.
Red Line 60103 SI-1 Fuel System Cleaner
Amazon.com: Red Line 60103 SI-1 Fuel System Cleaner - 15 oz.: Automotive
Almost the same thing?
Chevron 67740 Techron Concentrate Plus Fuel System Cleaner - 12 oz. : Amazon.com : Automotive
I can buy this locally for $4 when on sale....
