Old 12-22-2007, 02:23 PM   This thread is in the EcoModder Project Library | #1 (permalink)
2003 Toyota Matrix Block Heater
Well, I just got the block heater installed. It wasn't too bad. There was just a hole in the block on the driver's side above the transmission. The heater slides in with some grease over it and clips into the hole. Unfortunately, the hole is very burried and I wasn't able to take any real good pictures. Here are the ones I do have though.
I still have to see what of timer/remote I can find exactly for it though. But, that can wait a little bit at least.
Kit contents.
Heater installed.
Heater wiring. I routed the wire around the batter following the main wire harness to make it look clean. It then goes through the front of the car through the headlight hole along with a few other wires.
The plug. It is held in place roughly by the grill block. You can kind of tuck it up under it while it is not in use.
Old 12-23-2007, 01:32 AM   #2 (permalink)
EPA MPG #'s Slayer
diamondlarry's Avatar
La Forge - '07 Toyota Prius
90 day: 84.38 mpg (US)
DOHCtor Green MPG - '99 Saturn SL2
90 day: 49.17 mpg (US)
Silver Sipper - '00 Honda Insight
Nice clean job as usual Daox. That kit and it's location looks nearly identical to my Prius.
Old 12-23-2007, 09:33 AM   #3 (permalink)
It very well might be the same heater.
Old 12-23-2007, 12:36 PM   #4 (permalink)
90 day: 51.82 mpg (US)
I'm a little unclear about what type of heater this is.... Is it a frost plug installation? (IE does the element directly warm the coolant?)
Or does the element slide into a "pocket" in the block that's otherwise open to the outside?
Old 12-23-2007, 12:55 PM   #5 (permalink)
Your 2nd assumption is correct. There is simply a bored hole in the aluminum block. The heater slides into the hole with some thermal grease around it. It is secured from sliding out by a little metal clip that hooks onto the block. I assume they went to this style when they went with aluminum blocks. I'm really glad I didn't have to mess around and knock out a freeze plug. Thats what I thought I was going to have to do.
Old 12-23-2007, 12:57 PM   #6 (permalink)
Well! That's clever. It's the first I've heard of this type of engine heater installation.
What's its wattage?
Old 12-23-2007, 01:26 PM   #7 (permalink)
I wish I knew. It came with zero documentation.
Old 12-23-2007, 01:28 PM   #8 (permalink)
Do you have a kill-a-watt meter?
Old 12-23-2007, 02:54 PM   #9 (permalink)
Nope.
Old 12-23-2007, 02:57 PM   #10 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
You should definately pick on up,
