Old 03-22-2008, 09:53 PM   #1 (permalink)
Hybrid Grille Block/ HGB
Do you like the name? I am at odds
The Hybrid Grille Block with the big holes will allow plenty of air flow with the plugs removed. If you look there are two types of big plugs, only one of the plug samples works properly due to part thickness this is what is so time consuming in developing a decent product. The flat looking plugs are the ones that I will be using. In some of the photos you will notice smaller plugs the second prototype will incorporate around 12 to 16 holes and use smaller plugs due to the fact that I want to incorporate some unique features into the product. I will offer both styles. The product will attach using double sided stick tape unless the product is ordered otherwise. I will also offer the product with no holes at a lower cost.
Any feed back would be awesome.
Thanks for every ones help and hopefully once I can get some funding from this first product I will be working on some wheel skirts and such.
They will hopefully be on the market at the end of the month.
Thanks Franklin
http://www.HybridEffects.com
Prius aero mods (undertrays, grille block, mirror delete...) krousdb Hybrids 42 06-05-2011 03:27 PM
How does a grille block improve warmup time? fanamingo EcoModding Central 30 05-03-2010 06:13 PM
Home-made grille block / bra jodydewey Aerodynamics 5 04-05-2010 02:27 PM
Video: active aero (grille block) via shape memory alloy MetroMPG Aerodynamics 7 01-31-2010 12:21 AM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 11:14 AM
