Old 11-23-2009, 10:31 PM   #51 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
The fuel injection was throttle body I duno if they work with that or not.
Old 12-12-2009, 09:16 PM   #52 (permalink)
Vandle - '69 E-330 chateau
ranger brad - '94 Ranger xl
drastic change
So, I'm still planning the samurai project, but I've had some developments.
I had a 1969 ford 1 ton van, with a 302 and auto tranny. Swapped it for a 79 bronco with 4speed and 460 engine. Rediculous I know, but it was cheeper than swapping my van to a manual, and with the really high gears in my van my best ever tank avereage was 8.31mpg! driving like a grandma too. Talked the guy with the bronco into letting me put a tank through it before I swapped, didn't actually take that many miles.......:-) got 12.24mpg!!!!
Still rediculous I know, but 32% increase in economy, with zero $$ spent, not too shabby. It is on 33x12.5 inch tires, with one ton axles, so I can haul as much weight as my van, but have 4x4 now too. Had a set of real truck chains for this size tire from another project, and a high lift jack/straps to use as a ghetto winch etc.
Like I said, I'm still going to do the samurai project, but this was fun as a super low dollar experiment comming from another angle.
That guy with the 2x4 f250 with the diesel/4speed is getting double factory specs with his, around 30. I'm betting I could do the same. My goal is 20mpg
Planned mods.
Walmart pizza pan smoothie wheel covers, I have aftermaket wide rims.
A/c delete, system missing hoses, just going to remove the rest.
Roof rack delete
External tire carrier delete
Fast-back soft top, I've got some nice canvas lying around from a yurt project, it'd be sweet if I could loose a few hundred lbs, and make a more efficient shape at the same time.
max tire pressure, probably pretty low, do what I can.
Dual fuel propane swap. It's cheaper, gets better mpg's if you up your compression, on the 460's upping compression just means finding some pre-73 heads bolting them on.
eventually a re gear in the axles, the granny low tranny and super low transfer case will get me plenty low.
lockers for 4x4 capability with little efficiency penalty.
E-fan
Headers, Jeffs bronco graveyard has some for my engine that claim a dyno'ed 21%mpg increase with this same engine over stock manifolds.
What do you guys think? Anybody else with a 32% increase in mpg for free
Old 10-15-2010, 05:26 AM   #53 (permalink)
Well, the project moved forward, been working on the cabin this summer like a demon and haven't been posting much.
Traded a sailboat for a 650cc dual sport (street legal dirtbike) got 55.45 for my many tank average if I stayed below 65mph. Thought I was doing great till I figured out 200bucks in tires every 5000miles, 500 miles between oil changes.... a lot more maintenance intensive than a car. and if I stayed under the gvwr I could only have 160lbs of gear besides myself.
So I swapped it last monday for a suzuki samurai, traded strait across, so I only have a few hundred in it. drove 240miles home with 4 steep 2000ft gain passes, and got 31.54 mpg, going off what google maps says the route is, since the speedo is disconnected and with oversize tires it wouldn't be accurate anyway. not too shabby. My parents live 5 miles from a 4 acre samurai only wrecking yard, so I got a used soft top for 50 bucks and patched 2 small holes in it with sail repair tape.
Oh, and it is on 225/75/r15's so like 28.5x8.5inch tires too! way bigger than stock.
I've got to fix the heater blower switch, and get a new water temp sensor and I'm good to go.
I'm thinking:
High lift jack instead of winch, can be used for two things, less likely to crap out on you, and with a 1900lb "truck" it should be easy.
All terain tires and chains instead of mud tires, truck already has them on with 2000 miles out of 50000, so good real economy to use them. Real truck chains can be used in mud as well as snow and work better than anything but tractor tires with 5 inch lugs. Lower rolling resistance
some sort of aero fastback top, either a stinger or a complete top. Interestingly to me, when I made my road trip home in it, the top was sucked up at highway speeds (into a more aero shape?)
thinking of useing webbing instead of tow chain for self extraction, the good tubular rockclimbing stuff, I have a huge wad of it, and it is much lighter/more compact than chain, will have to investigate further, again the 1900lb truck makes me think of this.
Bailing on the spool, but from a steering effort angle rather than safety, I'll start with a lock right locker in front, so it will have zero effect on road handleing unless hubs are locked. they are down to about 200bucks
Oh, a tuneup, that's right, I did 31.54 over the mountains with old nasty plugs/wires/ who knows what timeing etc.
I'm going to throw a k&n air filter on, not because they are the golden fleece, but because I literally pulled a new in box one out of the garbage, now that is economy.
Early sidekicks/trackers have a exhaust manifold that will bolt up to a 1.3 samurai motor. They are a long tube good scavenging style, that should give good torq. Am I right that if you can get torq improvement without using more fuel you get to upshift sooner and save gas? I could get one at the wrecking yard for 26bucks.
Have a dumpstered 12volt radiator fan. will see if I can rig it up to get rid off the mech. fan.
they are so little you can get a nice manifold back performance exhaust for 230 bucks, they have one that bolts to the tracker/sidekick upgraded exhaust manifold I was talking about, since I don't have welding capabilities right now.
been working on getting my tool kit paired down to the bare minimum without leaving anything out. to save weight.
Proudly importing snowballs to hell since 1982.
Registering a car based reverse trike in CA Carwhisperer EcoModding Central 58 07-10-2011 07:12 AM
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
Flashing yellow light skyl4rk EcoModding Central 5 08-01-2010 01:57 PM
CA Vehicle Code - Mirrors thebrad Aerodynamics 2 08-30-2008 11:03 PM
