Go Back   EcoModder Forum > EcoModding > EcoModder Blog Discussion
Old 03-19-2013, 03:09 PM   #11 (permalink)
Als Hx - '96 honda civic hx
I will order one tommarro thanks Razor this help alot.
Old 03-19-2013, 03:12 PM   #12 (permalink)
Originally Posted by CaliHxLB View Post
thanks 96-civic-ex, I had seen that scangauge does that and it makes it easier to know when lean burn should be able to activate. I also read that scanguage reads 00000 when lean burn is activated. Does amyone know what the newest version of mpguino is or the best version?
I should have been more clear,... as it stands it is only an MPG gauge, but as razor pointed out it is an open source device which means anyone can program whatever they want from it,... but with only the two signals I mentioned all you can really get is mpg. You'd have to start tapping into other signals to get that info.
The scan gauge 2 will give you most obd2 port info, but lean burn is not one of them(at least not directly. Monitoring the O2 sensor output should give you an idea of it staying lean, but doesnt really tell you you are in lean burn. Oh and I've read the gauges that connect to the OBD2 port are not accurate when it comes to mpg during lean burn,... the mpguino is better for that.
What I would suggest is getting an mpguino for accurate mpgs during lean burn, and an ultragauge (like a scan gauge but much cheaper) for all other info.
Old 03-21-2013, 01:31 AM   #13 (permalink)
I took too long to order, DSchmidt Technologies is out of stock till 4/2/2013.
I was reading some post about lean burn and found out the california edition hx doesn't have lean burn but, I'll put my money toward the fed ecu. The mpguinos should be back in stock soon. Sorry for the late post I was studying for midterms.
Old 03-25-2013, 01:47 PM   #14 (permalink)
I'd get an Ultragauge - it can read and clear error codes on many vehicles and also provides load, TPS %, etc.
It won't give correct MPG #s with lean burn, though. It will read 0.000 v on your O2 sensor when you are in lean burn (which you WILL have with a manual trans CA HX).
Old 03-25-2013, 11:23 PM   #15 (permalink)
I should be getting my fed ecu tommarro so I am expecting to be in lean burn more often so, I'm going with mpguino. I will get one when more become availuable, Ialso need to fix or replace my vss to get the right readings with the mpguino.
Old 05-31-2013, 02:56 AM   #16 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
I have MPGuino available.
But if you don't want to use Ultragauge to read those things, you can build for example this: DIY Air / Fuel Ratio Meter or some other. (that was first one i found written in english). Or just buy a ready-made from somewhere.
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
Old 06-01-2013, 05:43 AM   #17 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
Hi,
mpguino can show RPM when it is programmed to to so - it can get it from injector signal
mpguino is best thing for lean burn - it measures directly from injector. Yu probably notice it from instant mileage reading when it is in lean burn mode - should be much more economical reading.
I have mpguino calibrated in my car and it is accurate - under 1% error. (when taking 60L diesel, pump and mpguino readings difference is under 0.5L)
Check my signature for mpguino web link.
Meelis
http://mpguino.wiseman.ee/eng - get assembled mpguino from here!
