Old 05-23-2008, 10:14 AM   #1 (permalink)
SirKeats's Avatar
GeRide - '89 Metro *XFi
90 day: 54.26 mpg (US)
Idle Speed Adjustment '89 Metro
How might I go about adjusting the idle speed in my 89 metro.
After cleaning out all of the blockages in the tubes (see other thread) and replacing the PCV - my engine seems to now be idling faster. I suspect that at some point someone adjusted the idle speed not knowing the engine was being starved for O2... and now that air is flowing properly, the mix ratio is jacked up.
I tried to find instructions in my Chiltons, but as y'all know already - Chilton's blows and I can't seem to find any instructions.
I want to slow the idle down a bit so I'm not wasting so much gas at idle!!
Thanks!
Old 05-23-2008, 01:34 PM   #2 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
On the throttle body there is a black cap covering the idle screw. the screw is facing up so it is easy to adjust once you find it. Loosen the jam nut and turn the screw to get it right then tighten the jam nut back. It is easy once you find it
My Convertible Metro XFI Plug in Hybrid Project build log
Old 05-23-2008, 02:07 PM   #3 (permalink)
SirKeats's Avatar
thanks. just checking... but my 89 has the throttle body right? in my chiltons it says that mine is the EFI which they have in a different category from the throttle body models (think they call it TFI or something like that).
just wanted to make sure we were on the same page. thanks coyote!!!
Old 05-25-2008, 11:56 AM   #4 (permalink)
larryn2o's Avatar
some have a screw on the fire wall. it's just 2 hoses and a black tube with a screw. right behind the TBi unit. it only works as a fast idle adjustment.
Old 05-25-2008, 01:46 PM   #5 (permalink)
Pushrod - '02 Cavalier
Most computer controlled cars have ECU-driven electronic actuators (like stepper motors or solenoids) to control idle. If you've got a stepper, simply unplug it when it's in a position you like. If it's a solenoid, you may have to rig up throttle bypass hoses to get the idle speed you want.
I can't lower my idle below 900 because it will oscillate wildly due to the bouncing of the air to fuel mixture. There are significant fuel savings to be had by lowering the idle. It helps at stops, engine-on P&G and neutral coasting. It's easier to do on some cars than others.
Old 01-23-2010, 09:28 PM   #6 (permalink)
high idle
I have a 98 Chevy Metro with a 3 cly 5 speed trany I just bought it and it idles a little slow when started, then when it's warmed up it idles way to high. Is the a adjustment somewhere or do I need a whole new throttle body.
Thanks
Old 01-27-2010, 09:20 PM   #7 (permalink)
TB adjustment
adjusting the TPS, what's the TPS and where is it?
I took off my 1996 TB and was looking it over and where the Throttle cable attaches to the lever that is spring loaded there is a black round knob with a screw end. what is that for? Is it something that will help in the adjusting it? Could someone tell me more about that?
Thanks
Old 02-08-2010, 03:23 PM   #8 (permalink)
engine service light on
Now I put on another TB and the idle is a little low when warm, not bad. And a good idle at start up. I ran it for about 20 miles then the engine service soon lite came on. What would of caused that. I did replace the front small vacumme line as it had a small crack in the hose. I cleaned the TB prior. It was in a 96 geo and the lite was not on. Thanks for your help.
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 01:59 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
mpg vs. speed - Metro graph MetroMPG Hypermiling / EcoDriver's Ed 26 06-05-2008 04:45 PM
'89 Metro - Has 13's... go 14's or bigger? SirKeats General Efficiency Discussion 11 06-04-2008 12:53 PM
Just picked up an '89 metro!!! SirKeats DIY / How-to 4 05-18-2008 03:46 PM
