Old 12-29-2008, 04:09 PM   #1 (permalink)
Impact/EV-1:a forensic reconstruction
I thought I would post the "numbers" portion of this thread now, and see if we can reach agreement on my methodology.There are images of the car in the archives in my aerodynamics photos album.
For references,I have relied on:EV1.THE ELECTRIC CAR.copyright,General Motors,1996; CAR and DRIVER,June,1994,p.94; MVP COMMUNICATIONS INC.,Troy,Michigan' "GM ELECTRIC VEHICLE,Ft.Stockton,B-ROLL";MECHANICAL ENGINEERING,October,1999,pp 74-77.
Brief History:
(Source: http://www.avinc.com/glossary/gm_impact_ev)
The EV-1 began life in 1988,as the" Impact",developed for GM by Aerovironment,Simi Valley,California,under the supervision of Dr.Paul MacCready.Impact went from a sheet of paper to a functional prototype in 18-months,and bowed at the Greater Los Angeles Auto Show in 1990.
After four permutations and assistance from Delco-Remy,Delco Electronics,GM Aero Lab,and Hughes Aircraft Co., the"raindrop" car emerged on the market in 1996,as a lease-only EV-1,handled through GM's newly-created Saturn Corp.
Constructed at the Reatta Craft Center,Lansing,Michigan,the EV-1 was to achieve compliance for Zero-Emission-Vehicles mandated by the California Air Resources Board,which would allow GM to sell the rest of it's products in California,starting 1998.
Mechanical specs of interest to ecomodders are:
(source: I bet y'all are soooo jealous of me :-p 56K BEWARE!)
Height-1281mm ( 50.5 inches )
Width-1766mm ( 69.5 inches )
Frontal Area 1.9468 square meters ( 21.025 square feet )
Cd 0.188
Drag Factor ( CdA ) 0.366 square meters ( 3.9528 square feet )
Length 4309mm ( 169.7 inches )
Fineness Ratio 3.360:1
Power 102.2 kW ( 137-hp )
Voltage 312-VDC ( @ pack )
Tires P 175/65R 14 Michelin Proxima RR all-season radial with puncture-sealant
Curb Weight 1350 kg ( 2970 pounds )
Performance: Top Speed 129 km/h ( 80 mph )[electronically-limited].
Land speed record & modifications
During March 10-11,1994,the pre-production EV-1 was modified and run at the Bridgestone/Firestone Proving-Grounds,Ft.Stockton,Texas,for an attempt at the land speed record for electric cars.
The following modifications were performed for the event:
  • The car's interior was gutted save for one racing seat.
  • A complete roll-cage was installed.
  • The car was lowered 25mm ( 1-inch )
  • Windshield wipers and sideview mirrors were removed.
  • The cowl area was covered by a plastic panel and duct tape
  • Full-coverage wheel discs were screwed to the rims
  • A "six-pack",containing extra batteries was installed in the front passenger seat location,boosting voltage to 384-VDC
  • The LLR tires were replaced with Z-Rated Michelin tires.
  • "Race" weight is estimated at approx. 1573-kg ( 3460-lbs )
Vehicle envelope parameters based on mods are as follows:
Due to the 222.5mm ( 8.9 inch ) differential in wheel track from the front to rear,with the 25mm lowering,the car loses 0.0143 square meters ( 22.9 square inches ) frontal area.
As mirrors do not factor into EPA frontal area,their loss difference is factored as a function of" points."The EV-1 served as the aero "mule" in the development of the GM PNGV car,and 15-points were "allowed" for the mirror delete.(I will use this value in my computations).
Using delta-Cd 0.006 for the wheelcovers ( from John Shinella's Lockheed,Marietta,GA Trans Am Pontiac research ),the modified Cd is estimated at 0.167,frontal area 1.8451 m-sq ( 19.9278 ft-sq ).
Allowing for the increased voltage,the motor power is estimated at 125.784 kW ( 168.615 hp).
Available power is estimated using Mu= 95% ( given simple gearbox and high inverter efficiency at max. load ),for 119.497 kw ( 160.18 hp ) at the drive wheels.
With this setup,the car achieved 288.3 km/h ( 178.8 mph ) top speed ( a land speed record ).
Aerodynamic power requirements at top speed are calculated at 96.871-kW ( 129.854-hp ),leaving 22.622 kW ( 30.325-hp )to overcome the resistance of the Michelin racing tires.
The car was subsequently returned to the garage area where the "Yellow-Ferret," 400mm ( 16-inch ) aluminum boat-tail was added,along with fresh batteries and ice for the controller.
On it's next pass,the EV-1 achieved 296.3 km/h ( 183.8 mph ) for a "new" world record.
To investigate the contribution the boat-tail made to the new record,I reverse-engineered the Cd using the new top speed.
Since the two record speeds were within 8 km/h of each other,I used the rolling resistance power from the 288.3 km/h run,and subtracting from the available 119.497 Kw,I'm left with 96.871 kW left over for aero power requirements.Using" standard-air" density for convenience,yields Cd 0.153 as the boat-tailed drag coefficient,and CdA 0.2885 m-sq ( 3.2079 ft-sq ).
So what does it all mean?
Dr.MacCready predicted that a car,like the Impact,if produced as a gasoline-powered car,would achieve upwards of 100-mpg.California Air Resources Board's Tim Yau,using a Btu yardstick,estimated that Impact would achieve 80-mpg. In 1991,GM's Ultralite,sharing a different"look",but very similar CdA was introduced to the public with 100-mpg.
GM ultralite
Had a gasoline variant of the Impact been co-developed,to share the outward architecture of the Impact/EV-1,using today's typical 48-month product cycle ( 36 for Mazda ),an 80-100 mpg vehicle could have made it to showrooms by 1993.
If the EV-1 aluminum is traded for steel,weight is added for the I.C.power-plant and drive-line,additional weight is added for fuel tank and fuel,and then the weight of the battery pack is lost,the gasoline car comes in around 1075 kg ( 2366-lbs ),within 14 kg of the Saturn SC.
As I touched on in my short post on the Impact,to spread risk,and do to corporate linkups at the time,GM could have offered the gasoline version under Buick, Cadillac, Chevrolet, Daihatsu, Geo, Holden, Isuzu, Lotus, Oldsmobile, Opel, Pontiac,Saab,Saturn,and Toyota. And as the body of the car requires no exotic technological breakthroughs,the car could have hit the market priced similar to the Saturn SC,at about $ 14,000 ( US) in 1991 dollars,and as a 4-seater.
Today,with all the R&D long paid for,a car like the gasoline EV-1 could be sold by KIA for under $8,000(US),$5,000(US) by TATA,India,and perhaps $2,500 (US) in China.
The Following 7 Users Say Thank You to aerohead For This Useful Post:
Christ (01-10-2010), Dean (02-24-2010), NeilBlanchard (02-23-2010), Oval_Overload (03-09-2010), pgfpro (01-10-2010), tasdrouille (01-08-2010), texanidiot25 (05-09-2010)
Old 12-30-2008, 07:19 PM   #2 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
The EV1 was a nicely designed car but it was poisoned by its 1880s-tech batteries. How good would it have been with a little diesel?
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 12-30-2008, 07:35 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.26 mpg (US)
Big Dave -
About 80 MPG :
Thread: EV-1:America's fastest production car
Originally Posted by cfg83 View Post
Hello -
The 183 MPH sounds like a salt-flats speed record. What was the actual cost of production of the EV-1?
Here's something that will make you throw up :
General Motors EV1 - Wikipedia, the free encyclopedia
EV1 CNG
EV1 parallel hybrid
The parallel hybrid variant featured a de-stroked 1.3 L turbocharged DTI diesel engine (Isuzu Circle L), delivering 75 hp, installed in the trunk along with an additional 6.5 hp DC motor/generator; the two motors drove the rear wheels through an electronically controlled transaxle. When combined with the AC induction motor which powered the front wheels, all three power units delivered a total output of 219 hp, accelerating the car to 0-60 mph (96.6 km/h) in 7 seconds. A single tank of diesel fuel could keep the car running for 550 miles with a fuel economy of 80 mpg.
A similar technology is used in the 2005 Opel Astra Diesel Hybrid concept.
A bird in the hand ...
CarloSW2
American Solar Energy Society
Old 12-31-2008, 03:13 PM   #4 (permalink)
how good
Big Dave,the car would have done even better as a diesel,as the fuel itself has about 11% more energy than gasoline,and with greater low-to-mid rpm thermal-mechanical efficiency,it has better BSFC.
At higher speeds the advantage would decline do to higher inertia of reciprocating mass required to withstand the higher compression ratios and shock-loading.You might consider the difference between today's VWs,with gasoline and TDi variants.
The lesson for the EV-1's aerodynamics,is that all cars taste better and there's less filling with a low CdA.
Old 12-31-2008, 03:18 PM   #5 (permalink)
80-mpg
Big Dave -
About 80 MPG :
CarloSW2
Looks like the numbers can stand on their own merit.Very tasty!
Old 01-08-2010, 04:11 PM   #6 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Don't know how I missed this thread first time around.
Phil: thanks again for posting yet more excellent info in the forum.
(I hope you don't mind I took a few minutes to tidy up the formatting of the original post.)
aerohead (01-08-2010)
Old 01-08-2010, 07:00 PM   #7 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
Can you index this under the Aerodynamic siminars?
Old 01-08-2010, 07:13 PM   #8 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
I don't know how I missed that either. The EV1 was such a beauty in every way. Thanks Phil!
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 01-09-2010, 12:22 AM   #9 (permalink)
Ecomodder en route
KITT222's Avatar
Vib - '04 Vibe base
Gotta love the 'ol EV-1. Too bad GM crushed 'em. But somehow, I can understand why. One person: Rick Wagoner. He killed the EV-1. He was a big believer in the SUV industry, which explains GMs guzzling decade. Wagoner even admitted it was a big mistake to kill the EV-1, and not make a hybrid until recently. GMs biggest mistake was allowing Wagoner to become CEO. I am a big lover of GM, and a supported of their new future and the Volt program, but Wagoner made some bad moves. He is the reason most everyone here hates GM.
Old 01-09-2010, 09:40 PM   #10 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
So, the EV1/Impact started with a Cd of .188. This drops to 0.167 with a mirror delete, short springs, and some duct tape, and 0.153 with a 16" boat tail.
That's a 11% improvement from stock to race aero, then an 8% improvement in Cd by adding the boat tail.
Hmm.... my car has more room for improvement at the rear than an EV1 ever had. I bet about 20% of my 0.25 Cd results from the trailing wake.
I'm just going to look at this picture and ponder for a while. Maybe I'll sit down with some cardboard and that spare rear bumper cover I bought.
How badly do I want 70mpg @ 70mph?
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/impact-ev-1-forensic-reconstruction-6566.html
Posted By For Type Date
Open Site Explorer This thread Refback 08-12-2011 09:43 AM
Firestone Oil Change Coupons This thread Refback 06-24-2011 01:43 AM
X Prize Winners Look Weird ? With Good Reason | Autopia | Wired.com This thread Refback 09-18-2010 11:50 AM
X Prize Winners Look Weird … With Good Reason | Autopia | Wired.com This thread Refback 09-17-2010 12:56 PM
Lightning Motors set AMA / FIM land speed record at Bonneville Salt Flats, bests Motoczysz — Autoblog Green This thread Refback 09-11-2010 12:53 AM
Where can I buy a VERY Powerful electric car motor? - Yahoo! Answers This thread Refback 07-03-2010 08:36 PM
03 Insight Whale Tail? - Insight Central: Honda Insight Forum This thread Refback 02-22-2010 12:13 AM
