Old 05-23-2011, 02:13 PM   #191 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
I read about how PSA is improving its 1.6 HDi turbodiesel by increasing the bore and shortening the stroke. This keeps the displacement, but reduces the surface area through which heat can be lost. The larger bore also allows slightly larger valves, which reduces pumping losses. I have no idea how much this helps FE, my guess is barely.
Cooled EGR and an intake restriction to help suck more EGR have been standard for years.
Piwoslaw's Peugeot 307sw modding thread
Old 05-23-2011, 02:23 PM   #192 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I haven't seen cooled EGR on any gasoline engine with the exception of the 2010 Prius. Are there others using it?
Old 05-23-2011, 03:44 PM   #193 (permalink)
Originally Posted by ConnClark View Post
The real gain is going with the direct injection.
I know I should know this already, but what is the advantage of direct injection?
Old 05-23-2011, 04:22 PM   #194 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
More precise control of when and where the combustion takes place in the cylinder (keeping the majority of combustion away from the walls of the cylinder).
Old 05-23-2011, 04:34 PM   #195 (permalink)
DieselMiser
ConnClark's Avatar
cooled egr on a gas engine
http://www.swri.org/3pubs/ttoday/Sum...n-and-Cool.pdf
Just keep in mind that the results these guys achieved was done through adjusting mixture as well as the EGR percentage (and other factors too) and not just simply cooling the EGR.
The Following 3 Users Say Thank You to ConnClark For This Useful Post:
Air-Hybrid (05-26-2011), cleanspeed1 (05-23-2011), Piwoslaw (05-24-2011)
Old 05-23-2011, 04:56 PM   #196 (permalink)
Interesting. Thank you.
Old 07-01-2011, 04:45 AM   #197 (permalink)
aero guerrilla
Piwoslaw's Avatar
Diesel
I recently came across a research paper which may be of interest. Tests proved that increasing EGR in a diesel lowers exhaust gas temperatures, which lowers NOx emissions, but too much EGR will increase PM and won't help milage.
Old 07-01-2011, 03:09 PM   #198 (permalink)
sc1 - '98 sc1
90 day: 46.37 mpg (US)
Tour bike - '011 Carp line Tour
This is in fact opposite, larger bores and shorter strokes have more surface to volume ratio in the combustion chamber.
- Tony
Old 09-20-2011, 11:52 AM   #199 (permalink)
CM400E - '81 CM400E
I was just reading an article in Automotive Engineering magazine and they were talking about Mazda's Skyactiv engines. Guess who is using cooled EGR on their 14.0:1 direct injection engines now? Yep, and 'large amounts' of it at times too.
The Following User Says Thank You to Daox For This Useful Post:
California98Civic (09-20-2011)
Old 02-28-2012, 07:31 PM   #200 (permalink)
oldschool
Olympiadis's Avatar
White2003Focus - '03 Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Irocz LB9
Last 3: 30.14 mpg (US)
Daox, I was curious to see the test results from your EGR experiments. Did you abandon the project?
Trouble Code PO401 EGR Flow Insufficient Detected Ford Man Off-Topic Tech 4 12-09-2011 12:45 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
My New 4cyl Compact Doesn't Get Good Mileage Stone Axe Introductions 5 08-11-2008 02:35 AM
