Old 09-10-2010, 11:00 PM   #171 (permalink)
oldschool
Olympiadis's Avatar
White2003Focus - '03 Ford Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 Chevy S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Dodge Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 Chevy C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Chevy Irocz LB9
Last 3: 30.14 mpg (US)
1999 C5 Corvette - '99 Chevy Corvette
2008 Infinity G37 - '08 Infinity G37
Originally Posted by mwebb View Post
in my experience , the system any system
will switch the EGR flow off
right away
before it will add any enrichment .
and
why do you think more mass is entering the combustion chamber when the EGR is on as opposed to when EGR is off ?
MOST current systems use MAF sensors NOT speed density systems
Load is DECREASED with EGR operation
repeat your testing with your focus to see .
You are right that most newer systems do turn off EGR flow when going into PE mode, but PE doesn't constitute the only enrichment possible.
The systems that still use AE routines do not turn off EGR.
At any rate, my statement was for Daox who seems to be interested in adding an extra, user-controlled, EGR system. I thought the information might be helpful in his tuning of his system.
When EGR is on, combustion efficiency drops, which requires more Oxygen and fuel in order to produce the same level of power asked of the engine.
Very basically, the calculated load would be ((old VE + extra VE) - EGR).
Actual mass moving through engine would be something closer to (old VE + extra VE + EGR)
By "VE" I mean the calculated air mass based on the sensor input (MAP or MAF).
EGR flow doesn't change actual loading against the engine, but EGR compensation does change calculated load, which is the only load that the ECM/PCM works with. The engine or ECM has no way to measure actual volumetric efficiency, nor does it need one. It only needs a way to reference the correct stored calibration data in order to keep fueling within a few percent of stoich, while the adaptive fueling routine does the rest.
As you can see in the first table in my first screen-shot, at any given calculated VE, with EGR-on the VE is multiplied by a reduction factor (calibration) that knocks down the original VE value - in this case about 35%, which in turn reduces the fueling value to match the predicted mass of Oxygen going into the engine.
In operation, if you start at a VE value of 35% with EGR off, but then turn on the EGR, you will need slightly more Oxygen to maintain the same power output level. This is achieved by a slightly larger throttle opening, which results in more intake air-flow, which then puts you up to a higher VE of say 54%. This new VE number is then multiplied by the EGR correction factor (54 * 0.65) to get the modified load value in order to calculate fueling.
At that point you have more total mass (necessary intake charge + EGR gases) going into the engine.
This increases effective charge compression because more mass is being squeezed and heated during the compression stroke. This is one reason that so much EGR can be added before combustion temp and efficiency drops to an unacceptable level. It's also the reason that such a high % of intake charge contamination results in such a relatively small loss in overall engine efficiency.
To propose that you can make an equal power level with LESS Oxygen going into the chambers would assume an increase in combustion efficiency. I think you'll find that an increase is extremely rare during EGR operation, especially the non-DC controlled systems. With small amounts of EGR you can see small increases in combustion efficiency under certain low-load conditions.
It can happen when:
a. peak combustion temp is not lowered a significant amount, and the amount of Oxygen is still high enough to maintain efficient combustion speed. Very little NOX reduction would be going on in this case.
b. The instantly added EGR spark advance correction precedes and/or outpaces the actual EGR flow creating higher peak combustion temp. This can happen as the EGR passages fill with particulate build-up, reducing the mass of EGR delivered. Again, NOX reduction would be minimal or non-existent.
c. The intake air charge is extremely cold and the EGR flow adds heat energy to the point that there is a net gain in combustion efficiency.
d. Some other scenario that I can't think of.
I will concede that my description of EGR operation isn't exactly what happens during 100% of EGR-on time, but it is fundamentally true for the majority of EGR-on time, even with newer systems. As I said before, what matters most is if you can get away with less engine power produced. In many operating conditions you can, but EGR operation during those times is rare or minimal. Again, I'm talking about EGR deliver strategy in factory form, not what you can achieve by fine tuning the system.
Any time you are discussing state-of-tune issues, different combinations can and will respond differently, as well as identical combinations under different operating conditions. That being the case, there will be instances where what I described doesn't hold true for some given period of operation time. It is quite rare to determine a tuning factor "rule" that you can't find an exception to if you try hard enough, or by accident through testing. That's why I don't discourage any sort of testing. An exception to a rule could result in a useful discovery.
I have no plans to re-test the EGR system on the Focus. I admit that I did NOT do extensive testing of that EGR function, nor did I trace the algorithm in the code. The only test with the Focus was for fuel mileage, day-to-day, and in highway test loops. EGR-off showed a very small gain in mileage on the highway, and a larger gain for day-to-day, which didn't surprise me in the least. The Focus is quite under-powered and responded very positively to increased power and throttle response. The difference was very noticeable as it often is. The wife even noticed the car being more snappy feeling. While throttle response is subjective and hardly conclusive, the less required TPS% and relative additional spark advance are quite measurable and significant. The PCM still thinks the EGR is active and functioning normally, though the EGR tube is blocked.
I did thoroughly test the EGR system on my 2001 S10 p/u. It does use a DC controlled system for precise control. Turning off the EGR in the calibration prevented the extra spark advance, so that wasn't a variable there. The result of EGR-off was a gain of 7.5% MPG on highway test loops. I did not test day-to-day mileage, but here again the subjective engine response was very noticeable. Being a V6 with an automatic trans in a 3500 lb truck, it too was under-powered for a good percentage of normal driving conditions. I was a little surprised at how much of a positive difference it made to turn the EGR off. Like you, I expected the newer system to do a better job.
I have yet to test or tune a vehicle where the EGR function added fuel efficiency, but I will certainly post up the information if I do. If I run into one it will probably inspire me to work with the EGR tuning to look for larger gains. I have never worked with a Geo Metro, but would be interested if the opportunity came up. I'm not working with EGR systems right now, but if one comes up in the future, what exactly would you want me to test or collect data from?
I'd assume you're thinking of TPS%, MAP%, MAF output, and calculated VE. I normally have to look at all of those closely during the tuning process. When something changes relative to the other, it normally requires a calibration adjustment.
Daox, if you see this as a thread hijack, please feel free to separate it out of your thread.
Old 09-10-2010, 11:36 PM   #172 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
your software looks neat
yes EGR reduces combustion efficiency
but it also reduces the effective size of the engine by the percentage of EGR flow
so add 30% EGR flow to a 3 liter engine
and
the engine becomes a 2 liter engine ... shazam ,and engine efficiency is increased by reduction of suction throttling loss if the operator chooses to maintain the same amount of "go" with EGR at 30%
..."When EGR is on, combustion efficiency drops, which requires more Oxygen and fuel in order to produce the same level of power asked of the engine.
no
actual mass will be Old AF mixture mass less the mass of the Old AF mixture that was displaced by the EGR .
plus the mass of the EGR .
until
the driver steps down on the throttle IF the driver feels the need for more "go"
so essentially
the mass of stuff in the combustion chamber is UN changed by the addition of EGR
until the operator requests more " go " IF the operator request more " go "
so
EGR in and of itself does NOT increase combustion chamber content mass
and the presence of EGR in the combustion chamber reduces
combustion pressure
combustion temperature
and NOX ,
relative compression and relative engine size are reduced .
suction throttling loss is diminished
all good things . when discussing FE .
so EGR (when in use ) creates a smaller engine with lower compression and less suction throttling loss , relative to a NON EGR type system
to restore big er engine power
switch off EGR , KISS .
in fact it (EGR) reduces the mass of air fuel mixture in the combustion chamber at the time.
in fact systems with too much EGR flow at the wrong time can reduce the max amount of " calculated load "available
by a substantial amount
which
also
increases FE . if the system is not flooded with EGR gas and misfiring
in Geo metros
cars with broken or poorly operating EGR end up with reduced FE compared to geo metros that do not have broken EGR systems
Old 09-11-2010, 12:03 AM   #173 (permalink)
oldschool
Olympiadis's Avatar
Team Ford
[COLOR="Lime"]no
until
so essentially
so
That's all true if you don't mind decelerating where you would have normally held a steady speed, or holding a steady speed where you would have been accelerating before, or accelerating much slower than before.
You could do all of this without the intake charge contamination, by simply using less throttle. The gain in combustion efficiency far outweighs the minuscule increase in throttling suction.
I was talking an apples to apples comparison, which assumes equal engine power output.
Also, as I said, when engine power output doesn't matter so much (you can get away with less), then the EGR isn't such a negative factor.
I believe you about the Metro dropping FE with a malfunctioning EGR system. Did you determine exactly why this happens?
What happens when the EGR is then turned off in the calibration?
Without the added spark advance you could then observe just the effect of the lack of EGR flow. Some algorithms use O2 offsets in the adaptive fueling routine to make up for EGR or AIR-injection. There are also O2 offsets for low RPM operation to make up for small changes in exhaust content due to reversion and charge-bleed during overlap. O2 offsets assume a perfectly functioning completely stock system. Normally you would notice a problem here by watching a WBO2.
Did the system indicate any knock? Did the spark plugs change how they looked?
Without EGR flow, one could assume that peak combustion temp and pressure went up, and some side-effect of this then caused a loss of FE. My initial thought would be too much spark advance under load, even if not enough to cause knock. I've not examined the EGR system on a Metro, so I will hold off on any more speculation there.
Old 09-11-2010, 12:29 AM   #174 (permalink)
mwebb's Avatar
no, it is a package
i disagree with what is above
and so do the facts
it is not just suction throttling loss , which effect is much greater than the value you attribute to it.
it is the whole package
use of EGR at cruise reduces fuel consumption and emissions
that is the fact
no way around it
Old 09-15-2010, 11:28 AM   #175 (permalink)
oldschool
Olympiadis's Avatar
Team Ford
- copying this here to keep EGR info together for the sake of search results.
It basically tests the O2 integrator offset during a steady load cruise condition once above 45 MPH.
Here are the calibration qualifiers for the EGR test on my truck:
; ERR 32 >> EGR <<
LD52B FCB 30 ; 30 SEC DIAG CYCLE TIME ENABLED IF IN MAP WINDOW
LD52C FCB 80 ; 40 Kpa LO LOAD DISABLE
LD52D FCB 208; 87 Kpa HI LOAD DISABLE
LD52E FCB 17 ; 6.6% LO TPS LIMIT (ENABLED IF IN TPS WINDOW)
LD52F FCB 64 ; 25% HI TPS LIMIT (ENABLED IF IN TPS WINDOW)
LD530 FCB 250; 98% EGR ON THRESHOLD
LD531 FCB 25 ; 2.5 SECs EGR ERR DELAY TIMER
LD532 FCB 3 ; 3 COUNTS FAIL COUNT THRESHOLD
LD533 FCB 10 ; 3.9% TPS, CHANGE TO DISABLE TEST
LD534 FCB 28 ; 2.8 Secs TEST DURATION
LD535 FCB 4 ; 4 COUNTS, INTEGRATOR DIFF FOR EGR OK
LD536 FCB 45 ; 45 MPH REQUEST TO ENABLE TEST
LD537 FCB 255; 99.6% EGR D.C, DECREMENT FOR TEST IN WORK (454cid TYPICALLY 50%)
Old 09-17-2010, 12:56 AM   #176 (permalink)
mwebb's Avatar
454 with 24.03 mpg - pretty amazing
a 1991 C1500 Pickup with a v8 454 throttle body engine that gets
24.03 mpg
that is pretty amazing - a miracle it would seem .
less than 4% change in STFT is all it wants to see for a pass ?
Old 09-20-2010, 12:38 PM   #177 (permalink)
Thanks for the concern Olympiadis (I honestly didn't read everything you posted, but did some), but I'm completely sure that EGR can in fact be used to increase mileage. Its already proven that EGR can improve power output by allowing more advanced timing and I don't recall exactly, but I imagine mileage as well. The fact that has yet to be tested is just how much mileage can be gained by it.
Anyway, I worked on my EGR circuit again this weekend. I had disassembled it since my tinkering with it last and found out the mosfet I was using had been fried. I have since gone to a higher voltage mosfet and also added a transil diode to help protect the mosfet.
With the circuit mainly done (need a hand dial-able pot and to wire it all up nicely for the car) all I have left to do is the physical work to the car. I hope to get the manifold modified in the near future and go ahead and install the EGR and block heater stuff together since it all requires dealing with coolant lines.
Old 09-20-2010, 03:40 PM   #178 (permalink)
PPS - anybody know where the EGR valve is on the Metro?
I had a quick look the other day and couldn't find it. I know the Suzuki 1.0L's have it - because a coked up middle EGR passage in the head is a common problem in older cars that can apparently lead to a burnt exhaust valve in the #2 cyl.
did quick search on erg on metro 1L .
Egr Valve - Auto Parts Warehouse
See if that looks familiar ,they normal mount them on or near to intake manifold with hose/tube going to exhaust manifold .
Old 09-20-2010, 07:56 PM   #179 (permalink)
cmj
Honda - '96 Honda Civic EX
90 day: 36.12 mpg (US)
I'm not gonna lie, I didn't read this thread thoroughly (Lots of info means lots of text to read)
Will I see an MPG increase on a MAP/TPS car if I remove the EGR/EVAP system?
Old 09-21-2010, 01:51 AM   #180 (permalink)
mwebb's Avatar
yes , we have no banannas !
you will see an increase , but it will be measured with negative numbers . if you implement your intended folly
not to mention
your intended folly is also a violation of federal law ,
so if implemented , you will become a criminal driving a car with decreased fuel economy and increased emissions .
yes , we have no bananas ! do the homework .
My New 4cyl Compact Doesn't Get Good Mileage Stone Axe Introductions 13 02-08-2013 12:06 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Trouble Code PO401 EGR Flow Insufficient Detected Ford Man Off-Topic Tech 4 12-09-2011 12:45 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
