Old 06-18-2012, 03:13 AM   #41 (permalink)
kurzer's Avatar
Knut - '07 Toyota Prius
90 day: 50.9 mpg (US)
Santa - '00 Hyundai Santamo
90 day: 29.07 mpg (US)
Originally Posted by gasstingy View Post
Has anyone done the kill switch mod as an ignition kill only? If you have, and been living with it for a period of time, please let me hear from you.
thats, what i did with my first start-stop-mod. it was not so good for me. the car tends to higher idle sometimes. if i killed it, the fuel was injected, as long as the engine was reving. in these moments quiet a bit longer, than useualy. the restart was so bad, that i didn´t use the killswitch above 1000 rpm.
on the other hand, was a restart after kill unter 1000 rpm literally immediadly.
doing a fuel cut, gives some more benefits. you can warm up with less fuel or extend the engine brake. here´s a vid about it.
what i recommend is, put the kill switch to the same side, as the gearknob is! that was the biggest improvment to the first car.
kurzer Gruß
Prius II
Hyundai Santamo
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
