Old 11-10-2013, 04:05 PM   #1 (permalink)
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 38.19 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 23.54 mpg (US)
Lightweigth OEM wheel list
I have searched now for OEM lightweight wheels for many years and found some jewels. I try to keep this list updated up to time to time so first post should have valid list of light wheels.
VW Lupo 3l 4½ J x 14, ET38 = 4.4-4.5 kg = 9,7-9,92 lbs
Citroen C5 "steel" 6.5x15" 4x108 ET 18 Weigth 4.7 Kg = 10.36 lbs
VW Lupo 5 J x 14, ET38 = 4.8 kg= 10,582 lbs
MB SLK type R170 5x112 ET37 7 J x 15 = 5,2 kg = 11,46 lbs
Renault Laguna "steel" 5x108 ET50 = 5.5 kg = 12.12 lbs
BMW E39 "steel" 5x120 7JX15 ET:20 = 5.7 kg = 12.56 lbs
Audi A6 C5 also A4 B5 5x112 ET45 6 J x 15 = 5.8 kg = 12,79 lbs
Audi A3 5x112 ET38 6 J x 15 = 6.0kg =13,22 lbs
BMW 3 series type 3B, 3/B ET47 7 J x 15 = 6 kg = 13,22 lbs
Renault 5x108 "Steel" 7x16 ET 50 =6.1 kg = 13.45 lbs
Audi A8 D2 5x112 ET42 7 J x 16 =6,1 kg = 13.45 lbs
MB CLK type 208 5x112 ET37 7 J x 16 = 6,1 kg = 13,45 lbs
MB C-Class type 204 5x112 ET39 6 J x 16 = 6.8 kg = 15.00 lbs
MB E-Class type 211 5x112 ET33 7 J x 16 =6.8 kg = 15.00 lbs
Audi A4 B6 ET39 7 J x 15 = 6,82 kg = 15,03 lbs
MB SLK type R171 5x112 ET34 7 J x 16 = 6,9 kg = 15,21 lbs
Volvo Acrux 5x108 6J x 15 ET46 7.0kg/15.5 lb
MB C-Class type 204 5x112 ET43 7 J x 16 = 7.3 kg =16,09 lbs
MB E-Class type 211 5x112 ET42 7½ J x 16, = 7.4 kg = 16,31 lbs
MB E-Class type 212 5x112 ET38 7 J x 16 = 7,4 kg = 16,31 lbs
Audi A6 5x112 C5 ET45 7 J x 16 =7,5 kg = 16,53 lbs
Volvo Cordelia 5x108 6.5Jx16 ET52.5 7.5kg/16.5lbs
"steel" means its aluminium wheel that is pressed from sheets and looks like normal steel wheel. Conserning those aluminium steel wheel when buying from the internet safest way to be sure its aluminium is to try with magnet. Usually the wheels center piece is about >5mm thick
More wheels and pictures:
OTTO FUCHS KG: Car
I will try to write those fuchs wheel list to here but today I dont have the time for it. In short Fuchs wheels are one the best wheels you can buy if you are searhcing for light and reliable wheels.
More citroen and renault stock "steel" wheel will follow later when I have weighted the rims...
Reason why I would like to make also this kind of list is that these are usually very cheap to buy as there are many of them produced. You could get the Citroen C5 wheel for 30 € a set and thats a bargain.
If you have deep pockets or want more looks you can check this list:
WheelWeights.net - Database of Wheel Weights
I will try to make similar exel on these OEM wheels...
www.tuneko.com
Less drag = Less fuel
The Following 5 Users Say Thank You to Vekke For This Useful Post:
101Volts (05-08-2014), California98Civic (12-03-2013), Jyden (11-11-2013), oldtamiyaphile (12-31-2014), RPM (11-13-2013)
Old 11-11-2013, 12:18 AM   #2 (permalink)
Too bad pressed-aluminium wheels are not so common.
Old 11-11-2013, 01:11 PM   #3 (permalink)
euromodder's Avatar
GasDwarf - '13 Volkswagen up! EcoFuel CNG
Not exceptionally light, but not too bad :
Volvo Acrux 5x108 6J x 15 ET46 7.0kg/15.5 lbs
GasDwarf's fuel consumption :
Old 12-01-2013, 10:44 AM   #4 (permalink)
Mazda Miata wheels are relatively easy to find here in the US
Unlike most you list there
Table of Wheel Weights
I used the 5.2kg/11.5lbs ones myself. Paid like $150 for a set of four.
The Following User Says Thank You to G2TDI For This Useful Post:
Shortie771 (04-25-2017)
Old 12-03-2013, 07:10 PM   #5 (permalink)
Thalmaturge
Eeyore - '04 Honda Civic Hybrid
Go Pod - '00 Honda Insight AC
The Tinyvan - '07 Honda Fit Sport
First gen (2000-2006) Honda Insight 5.5x14, weight ~10.5 lbs.
Old 12-03-2013, 09:27 PM   #6 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 60.02 mpg (US)
90 day: 3671.43 mpg (US)
Don't forget center bore sizes. They make a difference in fit and affordability.
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
TexasCotton (05-09-2014), War_Wagon (12-03-2013)
Old 12-03-2013, 10:04 PM   #7 (permalink)
5 Gears of Fury
War_Wagon's Avatar
Spunky - '90 Honda Civic CX
90 day: 35.56 mpg (US)
Civic VX. I'm trying to remember what mine were when I weighed them but I think it was 11 pounds.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
Old 12-04-2013, 10:44 AM   #8 (permalink)
Cyborg ECU
The VX wheel is generally listed at 9.7lbs and the 1996-2000 HX wheel at about 11lbs.
Here's my list from my car's garage page... there are links to further info on the page itself, under planned mods...
Possible wheel swaps for gearing/weight advantages:
13" Civic VX 8 spoke (higher RPMs but only 9.7 lbs.)
14" Civic HX 8 spoke (approx 11 lbs)
15" Mini Cooper R81 Imola 7-hole (12.1 lbs)
15" Mini Cooper R86 star-spoke (15 lbs)
15" Mini Cooper R96 7-spoke (13.8 lbs)
15" Enkei Classic J-speed (14.1 lbs)
15" Enkei RP-F1 (9.5 lb)*
15" Kosei K4R (10.7 lb)*
15" Konig Helium (11.2 lb) 40mm offset, hub bore 73.1mm*
15" Acura Integra GSR (94-95, 16lbs)
Other size specs to double-check for any possible swap: Offset 35-45; bolt pattern 4X100; lug size 12mmX1.5; hub center bore 56.1mm minimum (larger needs spacer rings). For more info see 1, 2, and 3 (for general wheel size data across models).
The Following 3 Users Say Thank You to California98Civic For This Useful Post:
fearone (01-05-2014), jcp123 (04-14-2018), Shortie771 (04-25-2017)
Old 05-08-2014, 04:12 PM   #9 (permalink)
Burning oil to move air.
ausiasmobil - '06 Seat Leon 1.9 TDI Reference
90 day: 40.22 mpg (US)
EcoTxec - '99 Skoda Octavia 1.9 TDI 110 cv Laurin & Klement
90 day: 52.85 mpg (US)
thank for the list, do you think VW jetta mkiv wheels could be there lights ones?
Volkswagen Golf Standard Wheel Sizes: Offset, PCD, Centre Bore for Golf MK1, MK2, MK3, MK4, MK5 and MK6. | Which Wheels stock wheel optional, offset pcd hubs data etc
hub 57.1 mm
16x6.5 in 5x100 ET42 (steel from 00' New Beetle weights 9.0 kgs = 19.8 lbs)
15x6 in 5x100 ET38 (it seems there are some O.E.M. VW 15 in AVUS alloys with 7.5 kg or 16.5 lbs) but what about steel ones and other vag group 15 in alloys?
my 16in alloywheel with dunlop sport 205/55/16 new spare tire weight 18.8 kgs = 41.4 lbs
16x6.5 5x100 ET42 Skoda Alloy wheels weight 9.6 kg = 21.2 lbs
tire Dunlop SP Sport 2000E 205/55/16 9.2 kg = 20.3 lbs
I have michelin energy tires (B rr A wet grp) but i don't know the weight of them yet.
i will soon dissamble the alloy wheel so I can compare in same conditions.
http://www.tirerack.com/wheels/resul...0&autoModClar=
from 13.6 lbs to 24 lbs aftermarket alloy wheels
and if you do same search american michelin energy tire weights 9.5 kgs or 21 lbs
some questions about A3 "steel" rims:
i did some search in vag parts catalog and there are a serieal number with A in audi a3 5x112 steel wheels and in 2004 octavia there are with A and with ending K.
but i think in spain there were no pq35 platform with 15 in steel wheels sol.
i have to buy them from the dealer with correct serial number or do you think with winter tyres there will be cheaps in somewhere?
Sold:
Old 05-08-2014, 04:41 PM   #10 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
Toyota Hybrid wheels not good enough to make the list?
2009 Corolla CE Enhanced - 1.8L auto
350K kms
Lifetime : 6.111L/100km (38.761mpgUS)
EPA : 6.8L/100km (34.6mpgUS)
14lbs Prius rims, full upper grill block, partial front belly pan, folded mirrors, lowered 1.5", LRR tech tires.
cheap, light, oem, wheels
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
