Old 12-10-2011, 02:35 PM   #1 (permalink)
Black Knight - '94 Corolla
90 day: 61.92 mpg (US)
little help
ok I found everything I need but the VSS wire. Do i need to tap in to the 7A 9A or 10A. My gut says the 9A I just need someone to back that up.
Old 12-10-2011, 03:04 PM   #2 (permalink)
Eco-ventor
Princess - '92 MX-3 GS
House of Tudor
90 day: 33.52 mpg (US)
Send a message via MSN to jakobnev
Well 9A looks like the conditioned signal you want, 7A looks grounded and 10A like gibberish to anything but the speedo.
Remember, even if you win the rat race - you're still a rat.
2010: 454.92L for 5313.90km => 8.56L/100km (27.5MPG US) (5 months)
2011: 606.11L for 7754.04km => 7.82L/100km (30.1MPG US) (Full year)
2012: 170.10L for 2405.00km => 7.07L/100km (33.3MPG US) (In progress)
Old 12-11-2011, 04:28 PM   #3 (permalink)
ok now what I pulled the injector and i am getting 12v on both sides of the plug? here are the drawings on the car
continues over to
where do i tap into the injector now?
Old 12-13-2011, 09:26 PM   #4 (permalink)
JethroBodine's Avatar
Franken-Jetta - '90 Jetta GL
90 day: 51.61 mpg (US)
Starcruiser - '98 Pathfinder 4WD
90 day: 18.82 mpg (US)
To me, it looks like pin 1 on injector1(from the ECM) is the wire you are looking for for your injector signal.
I think you'll like this VERY handy tool. I know I do.
Number 7 on the current POE list at last fill.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
Bonneville or Bust 2012
Old 12-14-2011, 05:12 AM   #5 (permalink)
Eco-ventor
House of Tudor
I think you want the blue(?) wire that is fourth from the top where it crosses over from one image to the other.
Old 12-14-2011, 10:04 AM   #6 (permalink)
Yea I was thinking like you two its the (B) that heads over to the ECM. But while looking at it I noticed the (B) only goes to two injectors then to the ECM. Then the (B-R) goes from the other injectors into the OBD test port. So I was guessing that those are the ground signal wires that its looking for. Now my question is should I be able to spade my wire into the test port and then change the referance formula during calibration. Or should I just go and cut into the harness at injector 1 pin 1.
