Old 05-14-2011, 03:58 PM   #51 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
They're basically made of blue styrofoam that was "shaped" to fit the lower grille opening. They are held by zip ties and protected by a "carbon fibre" vinyl wrap.
It actually provides better cooling (184F vs 188F) than the previous lower grille block, yet it does a much better job at deflecting the incoming air to the sides.
The Following User Says Thank You to CigaR007 For This Useful Post:
justjohn (05-15-2011)
Old 05-14-2011, 04:04 PM   #52 (permalink)
block
It's seamless,with the O.E.M. look! Few will even be aware you've done it.And you can laugh as you make your way, away from the gas pump,towards the bank.
Old 05-15-2011, 08:28 PM   #53 (permalink)
CigaR007's Avatar
How about covering the open area (lower grille) with a mesh-like material to further restrict the air, without blocking it completely ?
Old 07-16-2011, 09:58 PM   #54 (permalink)
CigaR007's Avatar
Currently working on Stage 3 of the lower grille block. Been doing some prep work on the front bumper for last 2 days in order to "mold" the lower grille opening with 2-part foam.
The objective is to fill the entire opening with 2-part expanding foam and carve it so that it will be flush with the bumper lines. 3 holes will be carved in order to provide ample cooling.
As we speak, the lower bumper opening has already been filled with foam and I should start carving and sculpting the foam tomorrow.
Pics to come !
Old 07-18-2011, 12:07 AM   #55 (permalink)
CigaR007's Avatar
Here are the pics of the work thus far.
Working with 2-part foam can be tricky and messy. I thought I had a done a good preparation of the surface to facilitate the removal of the 1-piece foam block but it turned out to be a pain the @ss ! haha.
It has also been duly noted that I used too much 2-part foam which made the removal of the excess quite tedious.
I should be working (matching shape to bumper lines, sanding, carving) on the foam block (last pic) over the next few days.
That is all for now !
graydonengineering (07-21-2011)
Old 07-18-2011, 04:32 AM   #56 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Originally Posted by CigaR007 View Post
Here's my version of an adjustable grille block. Hope it provides some food for thought.
Basically, two solenoids pull the 3 flaps to create an opening, hence providing sufficient cooling to the radiator. The sidewalls are there to provide an improved cooling efficiency.
I would like the flaps to be more distant from the opening, but most solenoids only have a reach of 1 inch or so. A linear actuator is a possibility, but its cost makes it a bit prohibitive for now.
Still haven't decided if the system will be automatic based on coolant temperature or fully manual. This is simply a basic conceptual drawing.
Any thoughts and/or suggestions ?
I think that looks something that might even work on winter, because you can build that without any other slides than the one on the solenoid.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 07-19-2011, 12:36 AM   #57 (permalink)
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Nissan Frontier XE
90 day: 27.87 mpg (US)
I am working on a spring loaded shutter device that regulates air flow baised on air velocity. If you have one opening blocked and have an automatic shutter device on the other, you could have the best of both worlds. 50% airflow at slow speeds, and minimal at higher speeds.
Old 07-19-2011, 02:01 AM   #58 (permalink)
CigaR007's Avatar
A speed sensitive grille block is a great idea for areas where the climate is rather warm year-round. I want to retain heat as much as possible during the engine warmup in the colder months.
Old 07-21-2011, 04:12 PM   #59 (permalink)
CigaR007's Avatar
Comparison between the previous lower grille block and the new design.
Next step is to find some sort of hardening resin that will not make the foam melt. Any tips on how to finish it off ?
Thanks in advance !
The Following 2 Users Say Thank You to CigaR007 For This Useful Post:
ECONORAM (05-05-2012), HighMPG (09-12-2011)
Old 07-21-2011, 07:34 PM   #60 (permalink)
The lower part of your radiator is quite plugged! Since that is the most important part now that the upper grill is blocked. A clean radiator is a happy radiator.
The plugs are very nice! I might just end up doing something similar for my bumper grill. It would be very handy to be able to change the opening easily on a semi anual basis or even on the fly if needed for a mountain pass. Nice work!
-Miles
Best 15-mile commute city/highway mix: 37.7 mpg
Best tank so far: 31 mpg
aero mod, grille block, toyota echo
