Old 10-22-2011, 08:19 AM   #101 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Originally Posted by IamIan View Post
You left it too open ... and too easy... prepare to go back on your claim ... or conceed.
Even with old tech ... using lead acid batteries , etc ... a 1,500 HP BEV Locomotive that runs for 12 hours per charge ... can pull much more than a 16,000 lbs trailer ... a modern version using modern components like Lithium batteries ... would easily be able to run for 4x a long as this Lead Sled.
Here's a picture of the Lead Acid one in Altoona Pa ... they built to test the platform of a BEV Locomotive without a diesel generator.
100% agree.
I agree ... it is an arbitrary point in the system ... just like picking the fossil fuel and ignoring the energy efficiency losses from solar energy to produce that fossil fuel it in the first place is also an arbitrary point in the system.
But it is the arbitrary point in the system that our current MPG system is based on... it is the currently widely accepted standard.
We are not likely to change our entire MPG system the public uses, by including the losses up-stream... the public expects 1 gallon pumped to = 1 gallon ... to go 30 miles when they drive 30 miles ... etc... is that an arbitrary point in the full energy cycle ? ... of course ... but that is the way the public does it at this time ... that is the current standardized method.... as flawed as it may be.
Nice train, you still don't have an electric pick up that nears my requirements.
I thought the DOE put all of this to bed with their extensive study http://frwebgate.access.gpo.gov/cgi-...4446-filed.pdf
12.03 KWH = 1 GAL U.S.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
New personal record: 632 miles on 1 tank. 48 MPG in my Auomatic 05 Corolla blackjackel Success Stories 6 11-30-2009 01:02 PM
About 4 miles per gallon RandomFact314 Hypermiling / EcoDriver's Ed 21 08-30-2009 05:24 PM
Various transportation methods, how many gallons to go 350 miles Daox General Efficiency Discussion 27 04-06-2009 01:56 AM
Why SUV fuel economy is so much more important than small car fuel economy... SVOboy General Efficiency Discussion 30 02-23-2009 06:26 PM
What's your best bet for an automatic? Crono EcoModding Central 16 10-22-2008 01:14 PM
