Old 04-17-2012, 02:32 PM   #1 (permalink)
mpguino install
Well excited got my mpguino in and blah reading are off bad. I have a 92 accord sedan with the pt6 ecu manual shift.
Im getting reading on it but the rpm/speed is way off and the mpg coming off of it are reading at 00.90 something, never goes over 1.0 and rpm is off by about 500. Im guessing the vss and injector wires i installed wrong or something since there all off. Idk what do you guys think, dont wanna get a new tank of gas till I have this figured out.
From what I read from others the orange wire at the ecu is the vss wire to tap into (maybe ill solder the actual wire to it, right now its spread and wire thru the hole). Brown wire on a1 is my injector lead. Any assistance guys be much appreciated.
Old 04-17-2012, 02:57 PM   #2 (permalink)
After further researching i think my wires are right, think my calibrations are extremly off. I just followed another accord guy with his number that were accurate per him.
settings
VSS: 8208
ms/gal: 196692124
tank: 17.1 gal or 17100
Old 04-17-2012, 03:53 PM   #3 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
does speed read 0 when standing and goes gradually bigger when accellerating?
similar to injector: gallons/hour reading goes bigger when revving engine?
RPM value should need only one parameter for calibration - "Pulses/2 revs" - I had to set it to 1 (default is 3) because RPM showed 3 times bigger revs
Old 04-17-2012, 04:01 PM   #4 (permalink)
stays at 5 or 7,then when i acclerate goes up and when shifting drops down and then goes goofy and reads very low
lol btw i need to take a pic of it for ya, for right now i love it just gotta try and calibrate the actual mpg which will take a bit but wanna figure out this speed and rpm
Old 04-17-2012, 04:12 PM   #5 (permalink)
just droped the rev to 1 and its reading accurate rpm now, the speed still sitting at 5 when i start the car, i rev it and it climbs strangely. Is there another calibration I need to look for that?
Old 04-17-2012, 08:12 PM   #6 (permalink)
JellyBeanDriver's Avatar
Which MPGuino code displays RPM? DCB's rev 0.86 doesn't
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
- http://www.dschmidt.com/MPGuinoJBD.html
Old 06-26-2012, 09:18 AM   #7 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
Yea, i would like to know that too
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
