Old 08-18-2010, 07:24 PM   #1 (permalink)
americasfuture2k's Avatar
SLOLANE - '08 Aveo5 SV
90 day: 30.55 mpg (US)
MPGuino and a Series 3 Supercharged
has anyone done one on a series 3 supercharged? i cant remember what the site is that has the cars list and their info.
since i am doing an engine swap on the fiero and i am using the stock getrag 282, wouldnt the PPM be the same across all GM cars since its 4000ppm? or am i not remembering this correctly? its been a while since ive messed with the MPGuino...
If you cant fix it with a hammer, then you have an electrical problem
http://www.cardomain.com/ride/3159589
shutup, im working on it
Old 08-19-2010, 10:24 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
It looks like no 3 series have gotten mpguinos, or nobody filled out the info (which is in the wiki btw).
MPGuino - EcoModder
Old 08-19-2010, 11:38 AM   #3 (permalink)
Phantom's Avatar
Bonnie - '98 Bonneville SSE
3800
90 day: 26.91 mpg (US)
The Series III Super charged is the same as the Series II. Chances are that no one has used a mpguino on the SII or SIII because the scangauge will work on it.
What is PPM?
I move at the speed of awesome.
Old 08-19-2010, 08:01 PM   #4 (permalink)
the S3 is different in a tiny, yet big way. a returnless fuel system for the big part. its run at a constant 60 psi and has 31.5 # injectors. better flowing supercharger, heads and UIM. other than that, its the exact same. different harness and computer of course. so a S2 info would not work on the fuel side of things.
PPM = pulses per mile. the GM standard that ive seen on a lot of cars is 4000. the stock fiero computer dives it in half... kinda dumb. a lot of gm cars n trucks use the same tranmission.. and in the olden days npt much of it was run off the computer.
Old 08-19-2010, 08:11 PM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
query, does the s3 maintain 60 psi in relation to manifold pressure?
re: ppm, you can get close with the speedo check in minutes, refine on a hiway trip with odo/mile markers/gps, fuggetaboutit.
Old 08-19-2010, 10:16 PM   #6 (permalink)
yea it maintains that constant pressure regardless of manifold pressure. i think thats how GMs returnless system works. the 2002 C5 holds a constant 55-58 psi... i know its pressure is maintained by the varying voltage from the ECM to the fuel pump.
