06-14-2013, 05:05 PM
#21 (permalink)
Eco Sol
Originally Posted by Joggernot
Here is Pop Mech test of Fastskinz on cars. Hope the link works. Well, it seems I'm not allowed to post a link to it. So do a search on Popular Mechanics Fastskinz Test Drive and you should find it.
Joggernot
Not sure if this is the one you are talking about but HERE
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
06-14-2013, 05:10 PM
#22 (permalink)
Joggernot
Popular Mechanics generally does a better job than "Mythbusters." Here is MetroMPG's thread, which links to the article:
http://ecomodder.com/forum/showthrea...aims-8321.html
Originally Posted by Frank Lee
yeah we've been through that already
06-14-2013, 05:14 PM
#23 (permalink)
Eco Sol
yep, same page I linked
CR-Z Current Mods:
Max Sidewall PSI
06-14-2013, 10:16 PM
#24 (permalink)
We were posting at the same time. I just spent longer looking up quotes and links.
06-14-2013, 10:18 PM
#25 (permalink)
Eco Sol
Ah, didn't look at the time stamps. Thanks for the more informative post btw.
CR-Z Current Mods:
Max Sidewall PSI
06-15-2013, 04:55 AM
#26 (permalink)
Was the additional information necessary? It never is, when I give it!
06-15-2013, 05:04 AM
#27 (permalink)
They didn't do a quality job on the test either, they certainly could have anticipated the lights better, and techniques such as removing engine braking by switching to neutral would have helped.
Of course, the 'busted' is likely so they aren't appearing to 'endorse' it. Is all...
The Following User Says Thank You to toc For This Useful Post:
06-15-2013, 08:00 AM
#28 (permalink)
Always Too Busy
This is by no means perfect, it's just my thoughts and feelings after watching the episode.
By saying a few simple changes will double your mileage then busting it, you are missing the point of hypermiling. While it is true that none of the drivers added 100% to their original MPG, the improvements in MPG stretched 40% to 70% from little more than driving style changes. This is really impressive because none of them are experienced hypermilers—they are doing this without coaching, and without practice. Why?
Because driving style is the largest factor of a vehicle's MPG.
This doesn't mean that eco-driving is limited to driving style. I would say the largest hypermiling tip is the following: don't drive more car than you need. The single largest contribution to my MPG was switching from a 16MPG truck to a 42+MPG car. By doing this, I have increased my fuel economy by about 263%
One of the main points of the show was driving 45 MPH on the freeway. There is a moment where Kari laughs and asks if the chain of cars in her wake is because of how she's driving (here's a hint; YES). If you have a line of cars behind you while driving, you are an idiot, not a hypermiler. Hypermiling is all about compromise; getting the best MPG while not being a nuisance on the road.
Few hypermilers drive 45 MPH on the highway, rather the takeaway from “slowing down on the highway” is that aerodynamic drag is the cube of velocity, and slowing down a bit reduces your drag a lot. Instead of driving 65-75, slow down to 50-60.
By the way, what's with this “not slowing down on corners” business? Conserving momentum is a big part of hypermiling, but driving around corners so fast that your tires squeal is idiotic, unsafe, and a waste of perfectly good tires.
Finally, it should be noted that Tory and Kari drove different vehicles, the Malibu driven by Kari gets significantly less MPG than the Focus driven by Tory, so it's kind of not a wonder Tory got farther based on the control MPG, which was SET IN THE MALIBU AND IS THEREFORE FAULTY DATA.
~Matt
EDIT: P.S. thanks for perpetuating the stereotype that hypermilers are saving gas by being socially awkward and oblivious.
EDIT 2: P.S. thanks for perpetuating the stereotype that hypermilers save gas at the total expense of normality.
Current Car: 2023 Chevy Bolt EV
Retired Car: White Lightning
Retired Car: Betty White
The Following 3 Users Say Thank You to Flakbadger For This Useful Post:
06-15-2013, 09:24 AM
#29 (permalink)
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab 90 day: 20.98 mpg (US)
Awww, now, don't go and ruin my excuse. "No, of course I wasn't attempting a personal best on that offramp officer, that would be idiotic and unsafe. I am a hypermiler, and I was maintaining momentum in order save gas!"
The Following User Says Thank You to wdb For This Useful Post:
06-15-2013, 02:10 PM
#30 (permalink)
Ok finely saw it and seems like they set that myth up for failure.
The only time I shut the vehile off and put it in park is in the drive through, other wise its in Netrual just a click away from Drive
If I wanted to I could rig up a Netrual saftey switch bypass and start the vehicle in Drive. I had one riged up on my camaro for a few weeks about 10 years ago when the Netrual safety switch circuit went out.
