Old 04-13-2010, 09:37 PM   #31 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Originally Posted by comptiger5000 View Post
My Jeep rips 0-60 in 6.8 seconds, but runs a 1/4 mile in 15.2 at about 90.
Drag racing a barn has got nothin to do with efficiency, see pinky wave:
Old 04-13-2010, 11:14 PM   #32 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 18.97 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
I am not worried about going fast. I am perfectly happy with climbing a hill with 6000 lbs in the back. The only problem with the massive torque at idle is the tires sometimes spin in 1st and reverse if I am not real smooth.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 04-14-2010, 12:09 AM   #33 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I don't have that problem, really, unless I get up to Farmer's Valley inlet, which is a like a 40*incline off the main road, around a nearly 90* curve. If I get too low in the R's hitting that incline, I get some bad wheel spin on the inside wheel, usually, and end up having to downshift and feather the clutch for a second to "tame the beast".
I hope to take care of this with an LSD 3.55 gearset, but that probably won't happen for awhile. Instead, I normally just take the turn (which is a right hand turn) from the left lane, so I can make it wider and line up before I hit the incline.
Old 04-14-2010, 12:49 AM   #34 (permalink)
Team Pontiac
you wouldn't happen to have a bsfc map would you?
1991 F-250:
Old 04-14-2010, 12:55 AM   #35 (permalink)
Negative. Been searching, to no avail, thus far.
Old 04-14-2010, 08:23 AM   #36 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
Unfortunately, many manufacturers are reluctant to release this info. I haven't even managed to find a stock torque curve for my Jeep. But, I know the engine has plenty of grunt off-idle, and starts to get happy around 1200, and is really pulling by 1500-1600.
Also, DCB - That was just to prove a point that design for extreme low-end grunt and top end power tend to be mutually exclusive.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 04-14-2010, 09:59 AM   #37 (permalink)
dcb
needs more cowbell
dcb's Avatar
Yah, that's a gimmie. you move the torque curve left (i.e. rv grind) and you make less peak power. But it can be a good move for efficiencies sake when you are focused on operating at efficient rpms.
Old 04-14-2010, 05:51 PM   #38 (permalink)
Exactly. That was my point. Having an engine set up and a vehicle geared to pull hard at the low end will give better efficiency, and is able to haul more weight, while sacrificing top end speed. If I actually run my Jeep all the way through the RPMs, by about 4400, it's falling on its face FAST in stock form. Compare to a little Honda that has to rev to 3000 to do anything useful, and is still pulling at 6000+.
If people would take a lesson from the big I6 and V8 truck engines, and apply that logic to a little 4 cylinder, with appropriate gearing, we'd have a winner (kinda like what the Metro XFi was intended to be). It would have plenty of power around town, be very efficient, and still be plenty strong enough on the highway up to 65 or so. Unlike my old 2000 Hyundai Elantra 2.0, which didn't even start to wake up on the highway until 75+.
Old 04-15-2010, 02:28 AM   #39 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
To the OP!!!
HP is not some BS rating like you think it is. Its very real and very needed to compare one vehicle to another. If you understood engine cycle time you would get this.
History:
This is where the constant 5252 comes from.
The word horsepower was introduced by James Watt, the inventor of the steam engine in about 1775. Watt learned that "a strong horse could lift 150 pounds a height of 220 feet in 1 minute." One horsepower is also commonly expressed as 550 pounds one foot in one second or 33,000 pounds one foot in one minute. These are just different ways of saying the same thing. Notice these definitions includes force (pounds), distance (feet), and time, (minute, second). A horse could hold weight in a static position but this would not be considered horsepower, it would be similar to what we call torque. Adding time and distance to a static force (or to torque) results in horsepower. RPM, revolutions (distance) per minute (time), is today's equivalent of time and distance.
Now if we are measuring torque and RPM how can we calculate horsepower? Where does the equation HP=TORQUE * RPM / 5252 come from? We will use Watts observation of one horsepower as 150 pounds, 220 feet in one minute. First we need express 150 pounds of force as foot pounds torque.
Pretend the force of 150 pounds is "applied" tangentially to a one foot radius circle. This would be 150 foot pounds torque.
Next we need to express 220 feet in one minute as RPM.
The circumference of a one foot radius circle is 6.283186 feet. ft. (Pi x diameter 3.141593 * 2 feet)
The distance of 220 feet, divided by 6.283185 feet, gives us a RPM of 35.014.
We are then talking about 150 pounds of force (150 foot pounds torque), 35 RPM, and one horsepower.
Constant (X) = 150 ft.lbs. * 35.014 RPM / 1hp
35.014 * 150 / 1 = 5252.1
5252 is the constant.
So then hp = torque * RPM / 5252
Vehicle Horsepower Rating
In the early 1970s, the Society of
Automotive Engineers (SAE) published the standard J1349 which defined a
standard method of rating an engine’s horsepower. In a few words, the
horsepower rated under J1349 (or SAE net HP) is for a completely installed
engine, including all accessories and standard intake and exhaust systems. In
other words, it measures horsepower at the flywheel and excludes all transmission and driveline losses.
The J1349 standard was not without loopholes. Taking advantage of these
loopholes, some car manufactures are able to inflate their engine horsepower
ratings and therefore rendering the SAE net HP rating less accurate. This led the
SAE to introduce in 2005, new test procedures (J2723) for engine horsepower
and torque (See Certified Power - SAE J1349 Certified Power SAE International).
This testing procedure is optional. Manufactures completing it can be advertised as "SAE-certified".Transmission and Driveline Friction
The power lost in the transmission and in the driveline due to friction and
resistance is where a large portion of power is lost (See PMECH FRIC in Figure 1).
Compared to a manual transmission, an automatic transmission suffers more
losses due to its mechanical complexity and weight (increased friction), the
resistance/slip in the viscous coupling of the torque converter, the transmission
oil pump and hydraulic system. Not surprisingly, a 4 wheel drive vehicle suffers
even more losses compared to a 2 wheel drive vehicle. Also included in the
driveline power loss are the friction from the braking assembly and the friction
from the wheel bearings.
The Following User Says Thank You to pgfpro For This Useful Post:
Christ (04-15-2010)
Suzuki Swift (1994 sedan) Coast Down Numbers wyatt Aerodynamics 18 11-24-2009 04:03 AM
Areas To Avoid In Cross Country Mpg Trips Ptero Hypermiling / EcoDriver's Ed 8 08-23-2009 04:13 PM
Looking for outstanding efficiency numbers Ernie Rogers General Efficiency Discussion 16 05-10-2009 07:53 PM
Crunching Numbers... jdwave EcoModding Central 6 08-01-2008 06:12 PM
New EPA numbers rsx2002 EcoModding Central 7 07-18-2008 07:34 PM
