Old 07-14-2008, 05:02 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Need quick iduino help!
Where so I solder on the external 5v power supply for use in car sans USB?
Thanks
Old 07-14-2008, 05:22 PM   #2 (permalink)
4OVER4 - '85 Starion ESi
90 day: 24.97 mpg (US)
Auto - '87 Starion LE
90 day: 23.65 mpg (US)
Soarer - '96 SC-300
90 day: 25.27 mpg (US)
I'm using the BATT & GND connections at the ECU through a 1A fuse...
Old 07-14-2008, 05:48 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
To get 5 volts on to the iduino (once you have 5 volts), you can use any of the pins that say +5 , and use a GND pin for ground.
Old 07-14-2008, 06:30 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Got it fixed, new trouble thread coming,
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 05:35 PM
Quick and dirty fiberglass help? SVOboy Aerodynamics 3 06-22-2008 07:25 PM
First Goal Reached !! And quick ... trikkonceptz EcoModding Central 7 05-26-2008 03:28 PM
Quick and easy licence plate aerodynamic mod :D blackjackel Aerodynamics 7 05-13-2008 07:20 AM
Quick Review: '07 Chrysler Crossfire RH77 The Lounge 3 02-02-2008 02:33 PM
