Old 04-16-2016, 01:18 PM   #11 (permalink)
EVVette - '71 Chevy Corvette Coupe
You should be able to send additional lines, they will just get dropped.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 04-16-2016, 09:03 PM   #12 (permalink)
ChargE - '92 Mazda MX6 LX
90 day: 33.89 mpg (US)
WinterTransport - '07 hyundai Sante Fe SE
Originally Posted by adamj12b View Post
you should be able to send additional lines, they will just get dropped.
Awesome!
Old 07-31-2016, 11:21 PM   #13 (permalink)
An update that is not really an update. More like planning out loud.
No progress on this task as yet, but I have not forgotten about it. I'll be on Holidays in August and will hopefully:
- 1 - get the original code compiled under MPLab X
- 2 - make the couple of minor changes to allow RTD Explorer to work with it
- 3 - log the extra data that the AC controller does on interleaved lines.
Paul's code is quite different from the AC to the DC controllers, so it will be a bit of a kludge.
If that works, I'll do a mini test running my grinder as a load (I still have that set up in my basement) and verify that I didn't break anything in the DC controller code.
In my mind that should take about 3 days. So using my regular scaling factor it will likely take 3 WEEKS!
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
