Old 03-18-2009, 08:36 PM   #11 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
FYI, here is a site with lots of programming info.
It is probably where I got the "press on programmer" idea from.
ELM - AVR programmer
Note: I just use a usbtinyisp these days.
Old 03-19-2009, 10:14 PM   #12 (permalink)
dcb
needs more cowbell
dcb's Avatar
FYI, I dug out my parallel port isp programmer just now to see how it does under ubuntu. It hasn't failed once after dozens of attempts. It never worked this good on windows. I'm using 5v power from the usb port to power the target board also.
I just put these commands in a shell script and ran it with sudo (might need tweaking of course), and arduino should have made a hex file already:
Code:
export avrdir=/home/dave/progs/arduino-0011/hardware/tools
$avrdir/avrdude -C$avrdir/avrdude.conf -v -v -v -v -pm168 -cdapa -F -e -Ulock:w:0x3F:m -Uefuse:w:0x07:m -Uhfuse:w:0xdd:m -Ulfuse:w:0xef:m
$avrdir/avrdude -C$avrdir/avrdude.conf -v -v -v -v -pm168 -cdapa -F -Uflash:w:mpguino.hex:i -Ulock:w:0x2b:m
Old 03-25-2009, 03:07 PM   #13 (permalink)
zed sled - '74 260Z turbo/MSefi
Franklin - '98 Forester
Send a message via AIM to myplasticegg
Thanks a bunch DC!. The diagrams were very helpful in getting this thing going again. I had a hard time keeping the wires pressed to the chip when trying to re-burn the chip, the extra socket is a must!
It now runs 100% and I hope to ad the data for the 98 ranger to the wiki page in the next week or so!
Old 03-25-2009, 05:00 PM   #14 (permalink)
dcb
needs more cowbell
dcb's Avatar
Awesome news !!!
Old 05-21-2009, 03:58 AM   #15 (permalink)
68.9 mpg best trip
Mercedes 89 D - '89 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Octavia TDI PD
90 day: 42.04 mpg (US)
Send a message via Skype™ to oldbeaver
ISP programming question
Very interesting info, lot of it.
However, difficult to follow for me. I am a retired forester, just hobbist experimenter with electronics.
Suppose I have a chip (MPGuino chip) already programmed. I need to change units (from english to metric) and some sensor processing calculations.
The only language I know is Arduino 011 (kind of C++) . If I use the USB tiny ISP , can I edit the programm of the MPGuino chip and change some lines with the Arduino compiler from the notebook?
If not possible, what is the easiest way to proceed? Supose I want to use the USBtinyISP device... Can I bought it from you? Can you program my chip?
What solution do you advice me?
Thank you in advance for your help.
OldBeaver
Old 06-08-2010, 04:51 PM   #16 (permalink)
dcb
needs more cowbell
dcb's Avatar
just another option for isp programming, I've used this from arduino and it works well with avrstudio as well as other programmers, and the kit is $11 shipped!! I got it with the AVRISP-mkII firmware.
Make Your Own MP3 Player
Electric fifth wheel (DIY through the road parallel hybrid) friedlbug Hybrids 21 01-06-2010 06:54 PM
parallel battery pack question Daox Fossil Fuel Free 8 09-24-2008 04:17 PM
Yet another plug-in parallel hybrid retrofit - hub motors MetroMPG Hybrids 8 04-15-2008 08:21 PM
DIY Chevy Avalanche conversion to parallel hybrid MetroMPG Hybrids 2 12-01-2007 11:00 PM
