Old 03-02-2009, 07:45 PM   #1 (permalink)
zed sled - '74 260Z turbo/MSefi
Franklin - '98 Forester
Send a message via AIM to myplasticegg
Parallel Programmer
I have made my programmer using this method ( Arduino - ParallelProgrammer ) but I am not sure where to hook it up on my spiffie kit MPGuino. I see 4 sets of 2 jumpers (8 total) near the buttons... where else could it go?
thanks, Shane
Old 03-02-2009, 11:13 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
You probably need an isp connector for that programmer (2x6). The spiffie should be programmable with a standard usb cable though, like hooked to most printers/scanners these days.
Old 03-02-2009, 11:18 PM   #3 (permalink)
yeah, I had the resetting issue and it won't boot up now. I've tried to upload a new sketch, can't find it. Need to re-boot it.
Old 03-03-2009, 12:55 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
You can rig up connections to the appropriate isp pins on the cpu with whatever you have handy. Here is a schematic that has the isp mapping:
http://www.arduino.cc/en/uploads/Mai...-schematic.pdf
I made an "in circuit" adapter for my ftdi cable out of an extra DIP socket (plus hotglue and careful bending of the tips, reset cap, etc, etc). I just press it on while programming. Maybe rig something like this up if you plan on doing it more than once.
Old 03-09-2009, 08:40 PM   #5 (permalink)
Sorry for the stupid question, but what pins are what on the ATML chip. I know what numbers to tap into, but the chip itself isn't numbered.
Thanks, Shane
Old 03-09-2009, 09:19 PM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
for isp, MOSI, MISO, SCK, Reset, +5(VCC), GND
Old 03-11-2009, 08:21 PM   #7 (permalink)
I have everything hooked and i open the code in arduino 0011 Alpha (is this the right program?) It gives me an error;
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I have tried to run it with USB powering it and without.
Old 03-11-2009, 09:17 PM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
yah, the parallel guy is flakey in my experience. I wound up loading a bootloader and verifying that it worked by watching for the blinking.
Old 03-12-2009, 12:02 PM   #9 (permalink)
Ziggy - '95 S6 Sedan
Manfred - '97 A6 Quattro Sedan
90 day: 20.61 mpg (US)
Clarabell - '03 A4 Quattro Avant
Sherman - '98 A6 Quattro Avant
Cab - '96 Cabriolet
Those errors mean that the ATmega bootloader is not responding to avrdude.
Old 03-16-2009, 02:04 PM   #10 (permalink)
Is the chip dead or should I try get a better connection to the chip with the bootloader? I need to get this thing going again ASAP as it is graded.
Electric fifth wheel (DIY through the road parallel hybrid) friedlbug Hybrids 21 01-06-2010 06:54 PM
parallel battery pack question Daox Fossil Fuel Free 8 09-24-2008 04:17 PM
Yet another plug-in parallel hybrid retrofit - hub motors MetroMPG Hybrids 8 04-15-2008 08:21 PM
DIY Chevy Avalanche conversion to parallel hybrid MetroMPG Hybrids 2 12-01-2007 11:00 PM
