Old 07-18-2008, 12:39 PM   #1 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
Pickup tailgate up or down
Skyl4rk's my name and Engine Off Coasting's my game.
Below is a reasonable facsimile of my Toyota pickup. After watching the vids and checking out the mini hurricanes which form over the bed, it will be obvious that a boattail is desperately needed. However at this time my options are tailgate up or down.
I find it difficult to interpret the vids, however one thing is for sure, the back of the cab is a major problem, causing lots of turbulence. Vids were done at 2,500,000 Reynolds.
What say ye? up or down?
Nissan Versa Aeromods
Old 07-18-2008, 12:44 PM   #2 (permalink)
99metro's Avatar
putt-putt - '99 Metro Base
90 day: 58.76 mpg (US)
Dusty - '89 Bronco XLT
90 day: 13.89 mpg (US)
Cowboy - '90 Bronco XLT
90 day: 17.42 mpg (US)
HayHauler - '06 3500 ST
90 day: 18.03 mpg (US)
Tailgate up, if the only choice is up or down. If you believe mythbusters, tailgate off or tailgate off with a net would be better.
2006 3500 Dodge QC/FB 5.9 handshaker
Old 07-18-2008, 01:09 PM   #3 (permalink)
EOCOCD
RiseAbove's Avatar
CavalierAttitude - '99 Cavalier LS
90 day: 29.25 mpg (US)
What about with a low cost tonneau cover on the bed?
Old 07-18-2008, 01:22 PM   #4 (permalink)
99metro's Avatar
They say no on the tonneau. Here's some info:
PickupTrucks.com Forums: Gas Savings With Tonneau Cover?
Another test says yes:
Testing The Tonneau/ Fuel Economy Theory - Ford Truck World Articles
The mesh probably breaks up the wind back there and helps direct it out the bed.
Conclusion? I bed cap that slopes from the top of the cab, down to the tailgate would be ideal. Jury's out for the tonneau - needs some real-life testing. NasTrucks have them. I have an aluminum tailgate with louvers for towing my 5th wheel, but I can't tell the difference in FE.
Old 07-18-2008, 02:02 PM   #5 (permalink)
Tailgate up, at least from the videos.
With the tailgate up you're leaving a shorter wake -- the gate catches some of the turbulence from the cab and puts its momentum back into the vehicle.
ETA: "Shorter" as in vertical height. The trailing length isn't as important, it's the perpendicular area of the dead wake that "pulls back" on the vehicle.
Old 07-18-2008, 02:03 PM   #6 (permalink)
What? THIS IS MY GOOD CAR
justpassntime's Avatar
The Japillac - '87 Accord LXi Sedan
90 day: 31.77 mpg (US)
Ranchero GT - '73 Ranchero GT
Spaz - '83 S10 4X4 Tahoe
90 day: 27.53 mpg (US)
Send a message via ICQ to justpassntime
Have to agree with 99metro. He's right!
While the video looks good, the turbulence in the bed causes more drag than helping the air flow it kinda cancels out the advantage.
Honda...the economical, renewable resource.
Old 07-18-2008, 03:29 PM   #7 (permalink)
GMC Sonoma - '94 Sonoma
90 day: 36.97 mpg (US)
If the Mythbusters data is correct then it appears to me that the web type tailgate should easily be worth the money to buy or build it. They say they got 5% better efficiency. This means that a $4 gallon of gas would have an equivalent cost of only $3.80. With every 20 gallon fill up you would save 4 dollars.
You could easily make a web tailgate out of any old scraps of rope, canvas, clothing or whatever.
I also think it would be easy enough for anyone to test the actual fuel usage with a cruise control, a scangague or other means of measure fuel injector duty cycle (pulse width) and a level, traffic free road of a couple miles length in which to do some A-B-A testing. I may do it sometime but where I live I would have to drive at least 30 miles to get to such a road and would have to do this at 3 or 4 in the morning to avoid any traffic.
Old 07-18-2008, 04:00 PM   #8 (permalink)
This link was copied from the sticky at the top of the general efficiency forum. In wind tunnel tests the best result was "up".
http://ecow.engr.wisc.edu/cgi-bin/ge...hi1/pickup.pdf
Old 07-18-2008, 04:06 PM   #9 (permalink)
up or down
All trucks are different.In the aggregate,gate up is better,but so little different that unless very careful at the pump,you'd never know.GM has a patent for 1/2 tonneau ( back half only ),they say its as good as full cover.Ford research shows otherwise.I know that a 1/2 tonneau works on Toyota,Dodge,Chevrolet,and Ford half-tons.Figure on about 5% mpg improvement.
Old 07-18-2008, 07:21 PM   #10 (permalink)
I've seen tests of up, down, mesh, covers, and partial covers. However I have not seen anybody try louvers. Naively it would seem like better flow might be achieved by placing a series of horizontal louvers (perhaps just thin boards) where the tailgate used to be. If it's too turbulent side to side vertical lovers could also be added. With proper design it might straighten the flow out of the bed of the truck. Might.
SAE report: Pickup Truck tailgate aerodynamics... better up, down, or off? MetroMPG Aerodynamics 5 11-17-2011 02:35 PM
Test: F-150 pickup "cap on" vs. "cap off" @ 60 mph MetroMPG Aerodynamics 17 11-17-2011 01:44 PM
Report: Improving the Aero Characteristics of a Dodge Ram Pickup Truck MetroMPG Aerodynamics 34 11-12-2011 11:45 AM
Large Pickup Aerodynamic Mods buckyball Aerodynamics 43 08-02-2008 05:49 PM
More Pickup truck Aero bennelson Aerodynamics 16 05-13-2008 09:32 PM
