Old 10-12-2014, 03:53 PM   #1 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Pizza pan wheel covers tested!
So, I finally had an afternoon free and decided now is as good a time as any to quantify the numbers on smooth wheel covers on a Gen III Prius. It wasn't an ideal day, what with higher wind than I'd like, so I'll probably repeat this in the spring if I can find a calm day to do it.
1 mile of Champaign County Road 500E between Curtis Road and CR 1200N was used for testing. I chose this section of road for the low traffic and flatness; elevation is 704 feet at the north intersection, 703 feet at the midpoint, and 701 feet at the south intersection with CR1200N. Despite the location, I still had to redo one set of B runs due to tractor interference (it's harvest time).
Conditions:
Overcast, 59 degrees Fahrenheit. Winds ESE at 12mph. I would have preferred less windy conditions, but this is the only time I had to go out and do this. Additionally, as you'll see from the numbers, I believe windspeed increased a little over the course of the test.
Methodology:
5 sets of N-S runs, 3 with covers (A), 2 without (B), run A-B-A-B-A. I warmed up the car for 30 minutes and verified coolant temperature with Scangauge; I don't have an X-gauge for oil temperature so had to assume that half an hour was enough to bring it up to operating temperature. The car was left on between runs with cruise control set at 50mph; covers were removed and stored in the vehicle on B runs.
Results:
A1(N): 62.3mpg
A2(N): 66.9mpg
A3(N): 67.6mpg
Average: 65.6mpg
B1(N): 61.8mpg
B2(N): 67.2mpg
Average: 64.5mpg
Change: 1.1mpg (1.7%)
A1(S): 61.7mpg
A2(S): 62.1mpg
A3(S): 61.0mpg
Average: 61.6mpg
B1(S): 59.4mpg
B2(S): 60.2mpg
Average: 59.8mpg
Change: 1.8mpg (3.0%)
There you have it, an average 2.35% improvement on a car that represents "typical" low-drag optimization in the current auto market. When I do this again in the spring I'll try and find a set of the stock wheelcovers to test against.
ADMIN EDIT - Related threads from DIY aerodynamic efficiency modifications:
Experiment: smooth wheel discs tested on Chevy S10 pickup - 4.6% mpg improvement @ 65 mph
DIY coroplast wheel covers
Cheap factory smooth wheelcovers help MPG - Chevrolet Suburban
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 9 Users Say Thank You to Vman455 For This Useful Post:
aerohead (10-13-2014), California98Civic (10-12-2014), freebeard (10-14-2014), Insight for life (10-12-2014), MetroMPG (06-11-2019), PaleMelanesian (10-14-2014), pletby (10-14-2014), renault_megane_dci (10-12-2014), Xist (10-12-2014)
Old 10-12-2014, 04:21 PM   #2 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
So that's pizza pan vs alloy wheels ?
Old 10-12-2014, 05:19 PM   #3 (permalink)
Moderator
Vman455's Avatar
Correct, full smooth cover and no cover.
Old 10-12-2014, 05:49 PM   #4 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
How did you attach them? how do you keep from rubbing through the paint on your nice TRD wheels?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 10-12-2014, 06:55 PM   #5 (permalink)
Those wheels are too nice to cover up with pizza pans. I got a nice set of wheels too and was considering some lexan disks.
Old 10-12-2014, 08:43 PM   #6 (permalink)
Moderator
Vman455's Avatar
That's a picture of the stock wheels I found online; apparently, a lot of people add the TRD center caps (I forgot to take a picture of mine before putting the covers back on for the last time). The stock wheel covers the pans are attached to snap right onto those wheels.
Old 10-12-2014, 09:50 PM   #7 (permalink)
Those are the stock wheels for the prius minus the wheel covers?
Old 10-13-2014, 10:07 PM   #8 (permalink)
No, those are not the stock Prius wheels.
Cobb (10-14-2014)
Old 10-14-2014, 08:46 AM   #9 (permalink)
Moderator
Vman455's Avatar
Yes, they are--2012 on they're painted black, 2010-2011 silver.
The Following User Says Thank You to Vman455 For This Useful Post:
Cobb (10-14-2014)
