Old 10-20-2009, 11:35 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph
Above image clockwise from top left: aluminum frame, cardboard construction; finished
prototype; removed during A-B-A fuel economy testing; still frame from video of tuft-testing
Overview ...
This discussion thread documents the construction & testing of a temporary, proof-of-concept aerodynamic "boat tail" on a 1998 Pontiac Firefly (Geo Metro).
Some facts about the prototype ...
  • Weight: 5.5 kg (~12 lbs)
  • Length: it adds 1.4 m (~4.5 feet) to the car
  • Hard to park? No. The car + tail is only ~30 cm (12 inches) longer than a 2008 Toyota Camry (the most popular car in the U.S.), and shorter than a Ford F-150 (most popular truck). So it would easily fit in a normal parking spot.
  • Sturdy? Yes. I could shake the entire car up & down and side to side from the end of the tail.
  • Handling: I drove with the boat tail on the car for about 300 km (186 miles) at highway speeds up to 100 km/h (62 mph) and saw no change in handling. (Had to keep an eye on rubberneckers in other cars, though.)
  • Rearward visibility: obviously there's no rear window; the next version will have one
  • Tail lights: the car's original rear lights (brake, reverse, parking & side lights) were relocated to the end of the tail, as well as the licence plate
  • Ugly? Duh! It's a prototype made of cardboard and duct tape! But the idea is beautiful in my eyes. Most production vehicles are aerodynamic disasters on wheels, and I think that's ugly.
Testing the prototype ...
1) First road test: read my impressions of the first drive with the boat tail on the car. Skip down to Nov. 21, post #100
2) Tuft testing: the tail spent a lot of time in the poor man's wind tunnel (ie. being tuft tested). This means observing the motion of yarn tufts taped to the car. The tufts reveal the direction & nature of air flow, and indicate whether the design works or not. Tuft testing results can be seen in the YouTube video, below.
3) Fuel economy testing: I used a ScanGauge to do an A-B-A test (before/after/before) that revealed a 15.1% fuel economy improvement at 90 km/h (56 mph). For testing details: A-B-A testing results posted, Dec. 5th
The original discussion started here ...
These are the goals for the project:
  • design a removable boat tail under 5 feet in length
  • the disassembled pieces of which will fit inside the back of the car
  • lightweight, stiff construction
  • minimally "invasive" to the car (discreet mounting points, etc)
I'm imagining 6 separate panels that will somehow snap or wingnut on to a light frame that can be easily dis/assembled.
I've done lots of waffling on materials, but I think I'm going to go with aluminum for the frame and coroplast for the skin. Both for their lightness, and ease of workability. Assuming I can find black coroplast (Home Depot here only has white - $20 per 4x8 - and the sign making shop wanted an obscene amount for a 4x8 black sheet of it).
Runner up idea was a fabric skin - UV resistant boat top canvas (which I can get in black). But thinking about hurricane force wind that will rarely be coming from directly ahead of the vehicle made me think coroplast is probably better.
One task I've actually completed so far: I added 6 feet to the wiring harness of each of my tail lights so I can move them between the back of the boat tail and their stock position as needed.
Twice now I've pulled the car into the garage and fussed around with various building materails, from cardboard to styrofoam to wood to alumimum. Nothing built yet. I've spent a silly amount of time standing around looking at the back of the car.
I think I need to just start building!
Old 10-21-2009, 12:00 AM   #2 (permalink)
doviatt's Avatar
Grey Goose - '89 Metro LSI 4 door hatch back
90 day: 59.36 mpg (US)
I vote for boat canvas. If fabric is good enough for biplanes why not a car? You could use brass grommets to hook onto pins. Also works for lacing, cinch up points, or tie-down points. It keeps it flexible to fold up when not in use.
Interesting project. I'm following closely. I need to do something for my aero some day.
Old 10-21-2009, 12:01 AM   #3 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
Have you considered the Fiber Reinforced Plastic sheets at Home Depot, (the bubble texture shower wall stuff) It can take high heat, can be formed and is quite strong. Easy to cut and very thin. $27 for a 4x8 sheet.
Old 10-21-2009, 12:03 AM   #4 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Oh! This is gonna be interesting to watch! You might wanna check Rona too. Here 4x8 coroplast sheets are 16 and change at Rona.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 10-21-2009, 02:39 AM   #5 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Get a tent and mod it to glom on the back (or get similar materials and use similar construction). Light, easy to break down, waterproof, cheap. Has those strong yet light and flexy fiberglass poles.
I was thinking of a collapsible aluminum frame (all one piece, but can be folded in on itself/collapsed into itself, like when you lower crutches) with the boat canvas stretched over some chicken wire. The chicken wire will add enough stiffness that the canvas shouldn't deflect that much, and the whole thing can be removed/collapsed on itself, taking minimal space in the interior.
If built intelligently, a piece of the removed canvas could also double as a windshield sun-shield, as well as a couple pieces for the front windows. That would take some real engineering time, though.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 10-21-2009, 03:05 AM   #6 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
You may not need aluminum framing except as stiffeners. A bent coroplast corner is quite stiff. Modern plywood boats are often frameless, and better for it.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
Christ (10-21-2009)
Old 10-21-2009, 02:05 PM   #7 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Cool, I'd like to see what you come up with.
I used metal skin on mine because it was free, and because welding it to the frame made it rigid with not as much work.
Didn't get a pic of mine with the extended tailpiece before I took it off, but I've gotten my downstate mileage back after removing it.
Winter daily driver, parked most days right now
Summer daily driver
Old 10-21-2009, 02:56 PM   #8 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Insight
90 day: 98.7 mpg (US)
Metro,
I would go for the Styrofoam!!
The stuff is easy to cut/glue/form/sand/paint and so on.
Go for panels that are 1.5 inch thick. I think cost is around $15 per sheet.
After the shape is complete, add one layer of 6 ounce fiberglass cloth and epoxy to the foam, using the wet layup method. Make sure to add about 3 layers on all your hard-mount points, and embed wood blocks in the foam in these areas.
For a boat tail, you will probably go through about one gallon of resin, and if you use West Systems, it will set you back about $100/gallon. Cloth, about $40 or so.
The cool thing about foam is, after your done, it will look just like an automotive finish. Of course don't ask about how much time the sanding/glazing/priming and painting will take. But this is something you can do anytime you wish. Just take them off the car and start sanding. And you can still drive the car in between.
Just my $.02, Jim.
Old 10-21-2009, 03:03 PM   #9 (permalink)
Wonderboy's Avatar
98 Civic - '98 Civic EX
90 day: 42.62 mpg (US)
CRXFi - '88 CRX HF / XFi
90 day: 38.84 mpg (US)
01 Insight - '01 Insight
90 day: 48.58 mpg (US)
I've been pondering this as well. Not a priority at the moment with two other projects on the burners, but maybe something worth it for either of us to cobble something together as a mock-up for the AMEC run. Don't forget the use of strong magnets and/or suction cups! I really feel like neodymium magnets or strong suction cups could be at least two of the supports for a removable boat tail.
Old 10-21-2009, 03:32 PM   #10 (permalink)
Except there should be no corners on this boat tail. All the "sides" of the boat tail will be rounded (think: more of a cone than a pryamid, so will need some kind of framework to support the shape. Correction: there will be hard edges where the boat tail terminates at the "transom".
Christ: the chicken wire idea to support fabric is a good one. But I decided against fabric because chicken wire or the supporting "tent pole" framework to get the polygonal "resolution" I want will be as bulky for storage or as much work as doing coroplast surfaces, I think.
Anyway, here's all I have to show so far. Should have enough length here to go almost to a point if I want to take it that far. (But I don't plan a point - it'll have a flat rear surface to mount the lights/licence plate.
boat tail, testing
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/project-geo-metro-boat-tail-prototype-15-mpg-10691.html
Posted By For Type Date
AeroProject: Impressioni da una gita fuori porta This thread Refback 01-10-2012 11:34 AM
BlogYueNMe: Aerodynamic tail makes Geo Metro even cooler This thread Refback 01-01-2012 04:20 PM
Club smart Car > The 100 MPG Challenge 2.011 This thread Refback 12-20-2011 08:20 AM
achieving an optimal shape This thread Refback 12-15-2011 12:39 PM
Elektromos Auto - Index Frum This thread Refback 11-22-2011 03:25 AM
Keversite.NL • Toon onderwerp - Dakspoiler This thread Refback 11-20-2011 02:49 PM
The ten nerdiest ways to modify your car This thread Refback 11-11-2011 12:10 PM
AeroProject: Pressione degli pneumatici This thread Refback 11-06-2011 05:20 PM
Raw video for: "Testing aerodynamic boat tail +15% MPG" - YouTube This thread Refback 11-03-2011 10:57 AM
17 DIY Cars Hacked for Fuel Efficiency : Page 6 : TreeHugger This thread Refback 11-02-2011 01:50 PM
DonsDeals: Aerodynamic tail makes Geo Metro even cooler - Hack a Day This thread Refback 11-01-2011 07:19 AM
BlogYueNMe: February 2010 This thread Refback 10-31-2011 04:28 AM
Hypermiling | Autopia | Wired.com This thread Refback 10-22-2011 08:54 AM
Energy News This thread Refback 10-17-2011 11:08 AM
MAKE | Green This thread Refback 10-10-2011 05:34 AM
"Offtopic-posts-topic" NSFW - Page94 This thread Refback 10-01-2011 05:41 PM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 09-28-2011 04:35 PM
Testing an aerodynamic boat tail - 15% better MPG - Geo Metro - YouTube This thread Refback 09-26-2011 10:21 AM
Attention, Greenies: Your Geo Metro Needs A Boattail This thread Refback 09-18-2011 09:09 PM
MAKE | DIY Projects This thread Refback 09-11-2011 05:12 AM
AeroProject: Aerodinamica ruote (parte 2) This thread Refback 08-30-2011 04:57 PM
AeroProject: Flow Illustrator Moviemaker This thread Refback 08-24-2011 05:10 PM
kamm back and golfball texture on rear of car. any design info? : engineering This thread Refback 07-27-2011 02:21 PM
‪Testing an aerodynamic boat tail - 15% better MPG - Geo Metro‬‏ - YouTube This thread Refback 07-20-2011 11:57 AM
Streamlined? - Page 2 This thread Refback 07-05-2011 07:40 AM
YouTube - ‪Testing an aerodynamic boat tail - 15% better MPG - Geo Metro‬‏ This thread Refback 06-29-2011 04:18 AM
Bil Hjemmelaget Båt Tail Car modifikasjonssett Gir Geo Metro Amazing Fuel Economy This thread Refback 06-09-2011 04:57 PM
archives for 04/2010 This thread Refback 05-14-2011 08:55 PM
Enterprising DIYer adds boat tail to Pontiac Firefly to boost mileage - Autoblog Green This thread Refback 04-11-2011 01:56 PM
The 100 MPG Challenge 2.011 - Club smart Car This thread Refback 04-09-2011 09:47 PM
Make: Online | MPG boosting tail cone This thread Refback 04-09-2011 03:19 PM
Pointes arrires This thread Refback 03-28-2011 06:36 PM
Motórum • Toon onderwerp - funny fototopic This thread Refback 03-17-2011 04:53 PM
Search Results firefly Hack a Day This thread Refback 03-11-2011 05:08 PM
impressive s2k mpg! - S2KI Honda S2000 Forums This thread Refback 03-01-2011 11:27 PM
AeroProject: Giusto per chiarirsi. This thread Refback 02-13-2011 07:38 PM
oldsmobile aerotech | Le Pics This thread Refback 02-10-2011 03:00 PM
Auto Home made boat tail Auto Retrofit Geeft Geo Metro Amazing Fuel Economy This thread Refback 02-01-2011 04:51 AM
Motórum • Toon onderwerp - funny fototopic This thread Refback 01-22-2011 01:25 PM
DIY automobile aerodynamic modification This thread Refback 01-14-2011 03:13 AM
Weight loss program for a Class B motorhome on an '89 E250 SD chassis - Page 3 - Ford Truck Enthusiasts Forums This thread Refback 01-09-2011 12:21 AM
Jullie mening gevraagd?? Onzin of waarheid?? - Focusclub.nl | Forum This thread Refback 12-15-2010 06:04 PM
Wind tunnel testing This thread Refback 11-24-2010 10:16 PM
Pointes arrières This thread Refback 11-09-2010 01:08 PM
Geo Metro: Geo Metro Photos, Wallpapers, Galleries, metro boat This thread Refback 11-05-2010 10:46 PM
Nopeusrajoituksia alennetaan 20-40 km/h! This thread Refback 10-03-2010 12:52 PM
Weekly Archive for January 3, 2010 : TreeHugger This thread Refback 09-17-2010 02:08 PM
Steel Aero Wheels For MoreMPG - RecycleBlog - RecycleBills This thread Refback 09-05-2010 06:40 AM
Coches eficientes y aerodinamicos sin comprar uno nuevo This thread Refback 08-26-2010 03:02 PM
Boat Tail - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 08-17-2010 06:35 PM
S2000 Forums -> impressive s2k mpg! : S2KI This thread Refback 08-14-2010 08:08 PM
geo metro - Jalopnik This thread Refback 08-10-2010 09:52 AM
Energy News This thread Refback 07-20-2010 05:27 PM
Enterprising DIYer adds boat tail to Pontiac Firefly to boost mileage - Autoblog Green This thread Refback 07-15-2010 06:54 AM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 07-11-2010 08:44 PM
Aerodynamic tail makes Geo Metro even cooler | PS2Cover.com News This thread Refback 07-09-2010 02:25 PM
????, ?????(??) : monogocoro ????? - Part 10 This thread Refback 06-23-2010 05:31 AM
cool but ugly Archives : TreeHugger This thread Refback 06-20-2010 11:13 AM
Detto | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 06-01-2010 03:00 AM
Keversite.NL • Bekijk onderwerp - Dakspoiler This thread Refback 05-31-2010 05:24 AM
Jalopnik: Obsessed With The Cult Of Cars This thread Refback 05-29-2010 05:04 PM
Autoblog Green This thread Refback 05-21-2010 01:36 PM
Bike Hugger: DL Byron: January 2010 Archives This thread Refback 05-14-2010 12:06 PM
citrina/straisniai/aerodinamika This thread Refback 05-06-2010 04:57 AM
ifeelgassy - Jalopnik This thread Refback 05-05-2010 05:58 PM
Home made boat tail auto Retrofit Geeft Geo Metro Amazing Fuel Economy Cars Transportation buildaroo.com This thread Refback 05-01-2010 06:27 AM
????, ???? : monogocoro ????? - Part 7 This thread Refback 04-25-2010 03:56 AM
17 DIY Cars Hacked for Fuel Efficiency : TreeHugger This thread Refback 04-23-2010 01:03 PM
Walden Effect: Homesteading and Simple Living Blog This thread Refback 04-19-2010 08:14 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 03-31-2010 10:09 PM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 03-31-2010 04:56 PM
Ricerca Aerodinamica | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 03-30-2010 12:52 PM
How To Change A Tail Light In Geo Prizm - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 03-27-2010 10:31 PM
Stop Aerodinamica | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 03-22-2010 05:06 PM
2009 December 25 | PS2Cover.com News This thread Refback 03-21-2010 05:17 AM
How To: Paritial Kammback This thread Refback 03-19-2010 10:00 PM
2010 January 07 | The Entertainment Blog This thread Refback 03-19-2010 04:00 PM
Fuel Economy | Autopia | Wired.com This thread Refback 03-06-2010 07:57 AM
La Cacharrería: un blog de tecnología diferente - Part 2 This thread Refback 02-18-2010 12:41 PM
S2KI - S2000 Forums -> impressive s2k mpg! This thread Refback 02-04-2010 02:28 AM
cars Archives : TreeHugger This thread Refback 01-30-2010 12:58 PM
Transportation-buildaroo.com This thread Refback 01-20-2010 04:54 AM
Kawasaki Triples WorldWide • View topic - Bike maintaining Tips .... This thread Refback 01-18-2010 01:53 PM
Anno | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 01-16-2010 12:36 PM
????, ???? : monogocoro ????? This thread Refback 01-12-2010 10:26 PM
Slashdot Submission | Aerodynamic tail on Geo Metro boosts MPG 15% This thread Refback 01-12-2010 07:13 PM
Slashdot - News for nerds, stuff that matters This thread Refback 01-12-2010 06:57 PM
Autopia - Part 5 This thread Refback 01-12-2010 05:47 PM
Cool Cars | Autopia | Wired.com This thread Refback 01-11-2010 04:28 PM
????, ?????(??) : monogocoro ????? This thread Refback 01-10-2010 01:04 AM
????? ??????????? ?????? ????? • ???????? ???? - ???????(????) This thread Refback 01-09-2010 10:03 AM
Ingeniøren Mobil This thread Refback 01-09-2010 06:27 AM
Spar 15 procent med en grim hale - Motorbloggen | Ingeniøren This thread Refback 01-08-2010 05:04 AM
Difícil de aparcar, sí; ¡pero gasta como un mechero! | La Cacharrería This thread Refback 01-07-2010 02:34 PM
monogocoro ????? - Part 4 This thread Refback 01-07-2010 10:58 AM
Motorcafè il blog dei motociclisti dalla mente aperta - Part 2 This thread Refback 01-07-2010 10:00 AM
Chuck Squatriglia | Autopia | Wired.com This thread Refback 01-06-2010 08:25 PM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Topic Powered by Social Strata This thread Refback 01-06-2010 07:00 PM
Design & Architecture Archives : TreeHugger This thread Refback 01-05-2010 12:58 AM
insidE of jaXonz This thread Refback 01-04-2010 11:02 PM
Buzz Punching: "Boat Tail" Increases Car's Miles Per Gallon by 15.1% This thread Refback 01-04-2010 10:47 PM
Guy Adds Boat Tail to Car, Increases MPG by 15.1% : TreeHugger This thread Refback 01-04-2010 03:28 PM
TreeHugger This thread Refback 01-04-2010 03:18 PM
Cars & Transportation Archives : TreeHugger This thread Refback 01-04-2010 02:16 PM
Items Tag RIT Make Club Idea Stream This thread Refback 01-04-2010 01:16 PM
Oszcz?dzaj paliwo z aerodynamicznym ogonem! (wideo) | Gad?etomania.pl This thread Refback 01-04-2010 12:14 PM
Teemu's planet This thread Refback 01-02-2010 10:15 AM
Bike Hugger This thread Refback 01-02-2010 08:55 AM
Daily DIY Network - Science Projects Plans Guides Blog Archive MPG boosting tail cone This thread Refback 01-02-2010 01:08 AM
Daily DIY Network - Science Projects Plans Guides This thread Refback 01-01-2010 08:22 PM
Make: Online This thread Refback 01-01-2010 08:11 PM
Autopia - Part 2 This thread Refback 01-01-2010 08:06 PM
siani_hedgehog's Friends This thread Refback 01-01-2010 06:09 PM
Make: Online : MPG boosting tail cone This thread Refback 01-01-2010 05:21 PM
Make: Online This thread Refback 01-01-2010 05:13 PM
A New Years Resolution - Bike Hugger This thread Refback 01-01-2010 12:17 PM
Firefly efficiency mods - MetroMPG.com This thread Refback 01-01-2010 02:42 AM
green hacks - Hack a Day This thread Refback 12-31-2009 04:02 PM
FFFFOUND! | flea-boat-tail-collage.jpg (JPEG Image, 500x363 pixels) This thread Refback 12-31-2009 10:56 AM
PWnT 2009 - (P)ost (W)hori(n)' (T)hread - Page 10598 - CarForums.net - Automotive Chat Forum This thread Refback 12-30-2009 08:08 PM
GeenStijl : Sneller, Scherper, Beter (maar eigenlijk komt hier een betere tagline) This thread Refback 12-30-2009 03:01 PM
Enterprising DIYer adds boat tail to Pontiac Firefly to boost mileage — Autoblog Green This thread Refback 12-29-2009 10:01 PM
Jalopnik - Attention, Greenies: Your Geo Metro Needs A Boattail This thread Refback 12-29-2009 09:46 PM
Interesting New Products and Inventions: Boat Tail improves Mileage This thread Refback 12-29-2009 08:25 PM
Autoblog Green — We Obsessively Cover The Green Scene This thread Refback 12-29-2009 08:09 PM
Attention, Greenies: Your Geo Metro Needs A Boattail - hypermiling - Jalopnik This thread Refback 12-29-2009 06:17 PM
Jalopnik: Obsessed With The Cult Of Cars This thread Refback 12-29-2009 06:16 PM
YouTube - EcoModderDOTcom's Channel This thread Refback 12-29-2009 05:19 PM
GeenStijl This thread Refback 12-29-2009 03:19 PM
GeenStijl : Tendentieus, ongefundeerd en nodeloos kwetsend This thread Refback 12-29-2009 12:41 PM
GeenStijl : Tendentieus, ongefundeerd en nodeloos kwetsend This thread Refback 12-29-2009 11:46 AM
GeenStijl : 15% zuiniger rijden met iedere auto! This thread Refback 12-29-2009 11:35 AM
GeenStijl This thread Refback 12-29-2009 11:16 AM
GeenStijl : 15% Zuinig rijden met iedere auto! This thread Refback 12-29-2009 11:16 AM
GeenStijl : Tendentieus, ongefundeerd en nodeloos kwetsend This thread Refback 12-29-2009 11:15 AM
La Cacharrería: un blog de tecnología diferente This thread Refback 12-29-2009 11:04 AM
Aerodynamic long tail improves fuel efficiency 15 percent This thread Refback 12-29-2009 04:24 AM
Autopia This thread Refback 12-29-2009 01:37 AM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 12-28-2009 07:55 PM
DIY ‘Boat Tail’ Gives Little Car Big Fuel Economy | Autopia | Wired.com This thread Refback 12-28-2009 02:22 PM
Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Madshrimps Forum Madness This thread Refback 12-28-2009 08:16 AM
R4 DS Cards, R4 DS and Wii Modchip News And Reviews This thread Refback 12-27-2009 04:21 PM
Mike Szczys - Hack a Day This thread Refback 12-26-2009 06:51 PM
transportation hacks - Hack a Day This thread Refback 12-26-2009 08:35 AM
mpg - Hack a Day This thread Refback 12-26-2009 08:05 AM
Friends This thread Refback 12-26-2009 07:57 AM
Hack: Aerodynamic tail makes Geo Metro even cooler -> ASTALAVISTA.com - the hacking & security community This thread Refback 12-26-2009 04:36 AM
the other end of the spectrum... This thread Refback 12-25-2009 11:44 PM
YouTube - Raw video for: "Testing aerodynamic boat tail +15% MPG" This thread Refback 12-25-2009 10:51 PM
YouTube - Testing an aerodynamic boat tail - 15% better MPG - Geo Metro This thread Refback 12-25-2009 07:07 PM
You put WHAT on your car? Stupid shit we've seen people put on their cars - The Something Awful Forums This thread Refback 12-25-2009 07:03 PM
Hack a Day This thread Refback 12-25-2009 05:24 PM
Geo Metro Mpg - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 12-24-2009 07:07 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 03:47 PM
