11-04-2013, 04:55 PM
#141 (permalink)
PSmodder lurker
The Following 2 Users Say Thank You to botsapper For This Useful Post:
11-04-2013, 05:01 PM
#142 (permalink)
Broken links in that article above - pity.
Found this:
NOAA PIFSC Quarterly Research Bulletin - Quarterly Research Bulletin
Middle: Yarn was placed on the cast and biotelemetry devices to help measure flow patterns and turbulence. Right: Drag was measured for various experimental attachments such as this submersible camera.
11-04-2013, 05:48 PM
#143 (permalink)
I try to be helpful. I'm not an expert.
The Following User Says Thank You to sheepdog 44 For This Useful Post:
11-04-2013, 08:54 PM
#144 (permalink)
My new favorite truck cab. At 0:27-29 you can see the wake bubble before the lowering pressure evacuates it.
11-05-2013, 09:09 AM
#145 (permalink)
I wonder where the air going into the front grille is exiting from.
Underneath I suppose?
11-05-2013, 12:45 PM
#146 (permalink)
I noticed that and wondered if the engine is racing in neutral.
It would be no problem with a VW Beetle. You just take off the fan belt and run the generator as a motor.
11-06-2013, 09:02 AM
#147 (permalink)
11-06-2013, 01:05 PM
#148 (permalink)
That magenta-colored smoke is something of a statistical outlier.
11-09-2013, 03:52 PM
#149 (permalink)
11-09-2013, 06:00 PM
#150 (permalink)
Mugen CRX
The Following User Says Thank You to CigaR007 For This Useful Post:
