Old 03-28-2018, 11:26 PM   #1 (permalink)
Reducing Brake Drag
I had some good success lately after I did a brake job. I spent a lot of time making sure the guide pins on the calipers were well lubed with silglyde. And I made sure the caliper pistons weren’t seized up. I used grease in the past for the guide pins but that doesnt work well if you have a pin that slides inside a rubber boot. The rubber can swell and cause the caliper to not slide back and forth very well. I use silicone now (silglyde). My car is a 1996 Saturn SC2. The big change I saw was the car will coast so much further now. P&G works better now. I am getting roughly 2 mpg better on avg.
On a related note, has anyone ever added springs to the calipers to help seperate the brake pads from the rotor to reduce friction? I looked at it but couldn’t figure out how to do it.
Old 03-29-2018, 12:05 AM   #2 (permalink)
brake drag reduction clips
Turns out these guys are all over it. Lots of threads if you use the search feature. I couldn't find any solid part numbers for a Civic VX though.
Old 03-29-2018, 06:29 AM   #3 (permalink)
Gaptooth - '00 Honda Insight
Gen-1 Insights
90 day: 58.91 mpg (US)
Such Fit - '07 Honda Fit Sport
90 day: 41.27 mpg (US)
Napa sells small springs you can put in your calipers. I have them on my Insight, but brake drag was very minimal to begin with. Next time I have my brakes apart I may try your suggested silicone lube. (That sounds weird to say?)
Xist (03-31-2018)
Old 03-29-2018, 08:58 AM   #4 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 56.37 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 41.79 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 49.59 mpg (US)
Here is what I did for my accord.
-Kaze o tatakaimasen-
Add yourself to the Ecomodder user map! As of 11/30/16 there are only 50 people on it!
125(Includes repeats...grr...) People as of 4/5/2018 Keep it up!
http://ecomodder.com/forum/showthrea...rmap-8247.html
Best trip in v6: 50.4
Best tank in CBR: 59.1
Best tank in VFR: 52.7
~the Cat and I watched the Supper Bowls today... tomorrow we will watch the Super Bowels...
The Following 3 Users Say Thank You to Daschicken For This Useful Post:
Gringo-Gaucho (03-29-2018), Piwoslaw (04-01-2018), Xist (03-31-2018)
Old 03-29-2018, 09:56 PM   #5 (permalink)
Excellent video! Thanks for that. I’m going to give that a try. I so surprised how much further I can coast. Now I have to remember to let off on the gas sooner.
Old 03-31-2018, 02:54 PM   #6 (permalink)
I wonder if these would work.
If not,
I have a spring maker, and he should be able to fabricate something for me (or others if it is universal)
MTB Bicycle Brake Spring Disc Caliper Brake Spring Mountain Bike Brake Clip Back Force Bicycle Practical Equipment Accessories-in Bicycle Brake from Sports & Entertainment on Aliexpress.com | Alibaba Group
Old 03-31-2018, 11:29 PM   #7 (permalink)
I use CV joint grease with molydisulfide. I doesn't seem to bother the boots. Use gloves if you plan on having children in California according to the label.
Old 04-01-2018, 04:16 AM   #8 (permalink)
This seems so simple, why is it not done standard from the factory???
Old 04-01-2018, 03:06 PM   #9 (permalink)
Because properly set up drum and disc brakes have very little pad drag. If they are dragging emnough to affect coasting, something isn't done correctly, or they are not maintained.
2000 F250 7.3 CC 20+ MPG @ 10000 #
2013 Golf tdi 50+ mpg
1988 Ranger EV Volt batts>> 12,000 MPG and climbing. HMMM ADDED A QT OF ATF does that count?
Old 04-01-2018, 04:35 PM   #10 (permalink)
Indeed but the manufacturers are trying to eek out every last bit of mpg. And this seems like a simple solution.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
