Old 12-15-2011, 05:38 PM   #21 (permalink)
Lebu
You may also want to dig up NASA's 'Large Eddy Break Up device,investigated for aircraft fuselage many years ago.I don't remember that they had any success with it,but the more info the better.
Old 12-15-2011, 06:46 PM   #22 (permalink)
Tenderfoot
ChazInMT's Avatar
MagMetalCivic - '04 Civic EX
90 day: 37.18 mpg (US)
I hate to be a wet rag on your fire here, but keep in mind that these winglets you are discussing are all fine tuning enhancements on vehicles which are very aerodynamic to begin with. They effect only a small amount of airflow around the vehicles. Putting these things on a pick-up truck which has the aerodynamics of a shaped brick is IMHO a waste of time and energy. You need to do things that affect mass amounts of air in order to see anything that is going to make an appreciable difference. Building a 2 ft kamm sorta thing on the front of your cargo box would probably net you the biggest easiest gain, a full on aerocap, would be better yet. Anything you do will be optimized by following the template.
Just sayin.
Old 12-15-2011, 09:40 PM   #23 (permalink)
I can appreciate your point, it is a good one. I must have my fun trying the weird and implausible before surrendering to the tried and true.
From a post/thread back in 2004 talking about "LEX Fences" and such.
Question for the Aero Experts - Page 2 - Pelican Parts Technical BBS
I did some highway driving today, the thought of attaching 24" long x 6" dia. PVC tubes at the edge corners on the roof and at the tail of the bed top came to me. The idea would be to tunnel/tube shoot some ram air where vortexes would normally start to form. Not my best idea, but I go though a lot of them. Then one day the urge to build slams me and I do something nutty and rather spontaneous.
Stay tunned.
http://s184.photobucket.com/albums/x...4%20Pick%20Up/
The tube idea really started as a pod idea, sort of F-104 and Caddy Tail Light.
http://ckparis.blogspot.com/2009/05/...-fins-and.html
EDIT 12/16/11
I found a patent somewhat similar to the trail edge/corner thing I've been thinking about. Again, a wing, and not a box (truck cab).
http://www.wikipatents.com/US-Patent...ing-tip/Page-1
http://www.britmodeller.com/forums/l...hp/t72943.html
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 12-15-2011, 10:39 PM   #24 (permalink)
IIRC, those fins you refer to as LEX fences are called vortex generators.I worked on these F/A-18 jets in the service back around '91
Old 12-15-2011, 10:47 PM   #25 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
200 lbs of downforce? I suspect that if I pressed down on that wing with 200 lbs of force you would hear your roof rippling.
Old 12-15-2011, 10:50 PM   #26 (permalink)
Read post #28
You are right.
The concept or lesson here is that vortexes can be tools and do a job.
Chin Spoiler:
Roof Wing
Old 12-15-2011, 10:54 PM   #27 (permalink)
I know what two, 65 lbs (130 lbs) of tube sand feels like over my rear axle.
I drew a diagram and stated that the increased down-force was because the rear spoiler was made more effective.
What part do you not understand Frank Lee?
Chin Spoiler:
Roof Wing
Old 12-15-2011, 10:59 PM   #28 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
I guess that's the part I did not understand! Well, it takes 20 min for all those quoted pics to load.
Old 03-08-2012, 10:34 AM   #29 (permalink)
Project EconoPolo - '04 Polo Twist TDi
90 day: 52.46 mpg (US)
Did you ever get this thing modelled in CFD? I could knock something up for you?
Viio
Amateur SolidWorks Flow Simulator
Link to my Project EconoPolo (aeromodding a VW)
Old 03-08-2012, 01:11 PM   #30 (permalink)
No I did not. Real life and seat of pants only, which is best, right?
I would be curious to see if CFD could handle the tiny air gap between roof and wing.
Do it up, I'll owe you a beer.
Chin Spoiler:
Roof Wing
