Old 11-16-2012, 03:25 PM   #1 (permalink)
Ol' Reliable - '02 Saturn SL2
Saturn SL airflow study
Just a little research here.
I made a quick and dirty profile of an Saturn SL in CAD (it is accurate as far as HxWxD) and ran an airflow analysis with some interesting results. There are 3 pics; 1 of the airflow over a stock car, 1 with the addition of a 6” “spoiler” on the trunk set at roughly 5deg down from horizontal (basically following the angle of the trunk lid and 1 with the wing and a simple rear pan (a basic diffuser).
You can clearly see a turbulent area behind the car stock.
The rear spoiler seems to clean it up considerably
The addition of the diffuser seems to refine the airflow a bit more. The diffuser could stand some more optimizing, for sure, but it does seem to work.
I was wondering if anyone has tried these mods and what their results were?
Any thoughts?
Like I said, just kinda playing around and thinking. I know the model is a bit crude (making a 100% accurate model would take a TON of time) but the results were interesting to me none the less.
ID:	11895   Click image for larger version
Name:	trk wg 2.jpg
ID:	11896   Click image for larger version
Name:	trk wg 6_diff 2.jpg
Old 11-20-2012, 01:09 PM   #2 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Cool simulation. You may be interested in this thread- http://ecomodder.com/forum/showthrea...ods-15529.html
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
